my velox rig questions
Post Date: 2014-12-02
Brannonsch View Drop Down
  Quote Brannonsch Quote  Post ReplyReply bullet Topic: my velox rig questions
    Posted: 02 Dec 2014 at 12:27pm
have a few questions how my configuration should hold up on new games and upcoming games. here are the specs
Processor: Intel Core i7 5930K 3.5GHz (Six-Core) (Unlocked CPU)
Motherboard: ASUS X99-DELUXE (Intel X99 Chipset)
System Memory: 16GB DDR4 2666MHz Corsair Vengeance LPX (High-Performance)
Storage Set 1: 1x SSD (250GB Samsung 840 EVO)
Let me know how this set up would run. thanks
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Dec 2014 at 12:46pm
Hi Brannonsch..Welcome to the forums.
You didn't mention your monitors resolution, but for a single 1920x1080 monitor this setup will game real nice. High to Max on most games.
You could save $243 and change to the 5820k cpu. The only difference between the two is, the 5930k allows up to 4 way sli, 4x video card, and the 5820k can do 3 way sli, 3x video card.   The Deluxe mobo also can only do tri sli, so save the money.
What cpu cooler did you configure?
Looks good and hope this helps.
Edited by bprat22 - 02 Dec 2014 at 12:49pm
  Quote Brannonsch Quote  Post ReplyReply bullet Posted: 02 Dec 2014 at 1:07pm
Acer 24 inch (Widescreen) (Black) (High-Performance Gaming Display)
I believe this is 1080p or higher??
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 02 Dec 2014 at 1:13pm
Most likely a 1080p, so you'll see excellent gaming.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 02 Dec 2014 at 1:53pm
Hi Brannonsch,
Bprat22 has already pointed out a couple of items. We can help you if we know how many monitors you will ever want and their resolutions. Plus your budget. You have a good start but you might want to tweak it a bit. You don't want to be system limited for future growth. But, you don't want to spend money you don't have to. If you will never need more than two GPUs you might save some money with a Z97 MB and the 4790 CPU. A darn nice platform for two GPUs or less. Definitely a better choice for a single GPU.
Edited by FrankW - 02 Dec 2014 at 1:54pm
