Need a buildPost Date: 2018-04-23 |
TheGameLover1
Newbie Joined: 23 Apr 2018 Online Status: Offline Posts: 6 |
Topic: Need a build Posted: 23 Apr 2018 at 4:55pm |
2000 to 2200 Expectations: [being able to play most games at 1080p and can handle more of the new gen games Usage: [mainly for gaming] Special Needs: [want it to not be to loud, need a good amount of storage.and a good airflow] Dont know the rest to do since im new to gaming Edited by TheGameLover1 - 23 Apr 2018 at 5:15pm |
DezLOver
Quote Reply Posted: 24 Apr 2018 at 4:32am |
Hi GameLover1...Welcome to the forums.
Best bang for your buck and keeping you within budget is the Vanquish level 4. Plenty of storage, a very strong gtx 1070ti card and the case has excellent airflow. If we showed you a custom build with updated parts your budget would be blown. Vanquish just works great. Hope this helps. |
TheGameLover1
Quote Reply Posted: 24 Apr 2018 at 8:00am |
should i add a 1080 ti?
DezLOver
TheGameLover1
Quote Reply Posted: 24 Apr 2018 at 8:03am |
how about the lumos since i can add stuff to it which is what im looking for you think thats good?
DezLOver
Cretae
DS Veteran Joined: 22 Mar 2010 Online Status: Offline Posts: 7328 |
Quote Reply Posted: 24 Apr 2018 at 8:06am |
Welcome.
He's right, but I think he means UPGRADED parts. Nothing out of date here but us old guys! Good luck. Was typing while you were posting. The 1080 Ti would be complete overkill and wasted on 1080p. While it's true you can't make changes to the Vanquish in your order, you can upgrade parts at a later date to your heart's content. Before I posted, I played around with a Lumos build just to see, and I was well over $2400 before I even got to the cooler. Unless you want to up your budget several hundred, the Vanquish 4 is the way to go. Edited by Cretae - 24 Apr 2018 at 8:17am |
