Need advice on 1080 SLIPost Date: 2016-05-27 |
Vertebreaker
Newbie Joined: 28 Apr 2013 Online Status: Offline Posts: 26 |
Topic: Need advice on 1080 SLI Posted: 27 May 2016 at 7:06am |
Hey all, I'm looking into configuring a 1080 SLI system, but I'm having trouble keeping it within my budget. Maybe that's not possible at this time, but I figure you might have a better way of putting together this thing than I do.
Budget: 3k, but willing to go a bit higher to make it work Expectations: 4K gaming and VR. Usage: See above Specifications: I'd like to use the i7 6700K and 2 1080s. Apart from that, I don't have too many other concerns about parts. Overclocking would be nice, but not required. If the Founders Edition is going to keep pushing me above 3k (the best I've been able to configure, so far, is about 3,284 before shipping), then maybe I'll have to wait. But maybe you wizards can do way better than me. Thanks for any help/advice! |
Quote Reply Posted: 27 May 2016 at 9:24am |
Hi Vertebreaker. Try this config. Just a tad over your budget but gives you the sli 1080 and 6700k processor.
Config # 1420337 Cost $ 3073 Chassis Model: Special Deal Hot Seller - Digital Storm Coridium Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices) System Memory: 8GB DDR4 2666MHz Digital Storm Certified Performance Series Power Supply: 850W EVGA SuperNOVA Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD (250GB Samsung 850 EVO) Storage Set 2: 1x Storage (1TB Seagate / Western Digital / Toshiba) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (GeForce GTX 1080 8GB (NVIDIA Founders Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex 120mm Radiator Liquid CPU Cooler HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) I would prefer a 1000 watt psu, but the 850 watt shopuld be fine. The HDD I always recommend the Western Digital Black for another $29. I did make some compromisers to hit your budget, but none that impact its performance or fun. Hope this helps and good luck. |
hoserator
DS Veteran We don't need no stinking "Avatars" ! Joined: 08 Oct 2014 Online Status: Offline Posts: 7960 |
Quote Reply Posted: 27 May 2016 at 10:21am |
bpratt22
Meller
Quote Reply Posted: 27 May 2016 at 10:26am |
I would possibly swap out the case for a Corsair Carbide Series Air 540 over that 450D. And the AIR 540 is cheaper. Since we are only water cooling the CPU with an AIO, a better air optimized case will pair nicely with the blower style coolers on those cards. Plus it has plenty of room in case you want to 1.) Add more Hardware and 2.) Watercool your GPU's in the future. I'd probably recommend upgrading your case fans too, to nicer fans... but Corsair does actually give you decent stock fans.
Custom PC
Quote Reply Posted: 27 May 2016 at 10:40am |
Yep, the Air 540 is an excellent alternative. Either work with reference cards. The air 540 is actually one of my favorites on the site, but recommended the Corridium for a more traditional looks..
Vertebreaker
Quote Reply Posted: 27 May 2016 at 11:47am |
Thanks so much for the build. Two questions:
1. Is the 8GB of RAM too low for future-proofing myself? I was assuming 16GB would be a solid choice for ensuring I don't need an upgrade for the next 5+ years, which is absolutely my hope. I assume they come in 2x4GB, or is it one 8GB stick? 2. I'm okay with the extra price for the 1000W over the 850W. Is it worth making the leap, just to be safe? Thanks again! Edited by Vertebreaker - 27 May 2016 at 11:48am |
Dax Doomslayer
DS Veteran Keeper of the commas Joined: 29 Apr 2012 Online Status: Offline Posts: 4737 |
Quote Reply Posted: 27 May 2016 at 11:56am |
The Air 540 rocks!! I love my little Borg cube and highly recommend it.
Meller
Quote Reply Posted: 27 May 2016 at 12:05pm |
You'll be fine for now. If you have 16GB of ram, running Windows 7 or newer, you'll at most (on average.. lol) use ~8GB of ram, give or take 1GB. If you only have 8GB you'll use around 4-6GB and idle at 1-3GB. WHen you have more memory, Windows takes the pleasure of increase the page file and just using more to use it because it's there. It should be a 1x8GB stick of ram. You can also request that to make sure. Then just save up the $40 or whatever and buy a matching DS branded 8GB in the future that they'd probably mail to you. And ram is extremely easy to install. |
Custom PC
Quote Reply Posted: 27 May 2016 at 12:15pm |
I think the 850 watt psu is fine unless you start pushing over clocks on both CPU and the cards. The 980ti in sli has a recommended 1000watt psu, and the 1080 uses much less. If you can, go 1000 watt and never look back, but the 850 is good imho.
Meller
Quote Reply Posted: 27 May 2016 at 12:18pm |
Agreed. With the low power consumption of the 1080's, a 1000w will be 100% future proof for you in terms of 1080 sli and overclocking. |
Custom PC
Vertebreaker
Quote Reply Posted: 27 May 2016 at 5:10pm |
Alright guys, I pulled the trigger on bprat's build, except I swapped in the Air 540 case and the 1000W PSU. The 540 actually helped bring down the shipping cost, so that was nice.
Thanks again for your insight, especially to bprat for once again helping me. You were one of the first to respond way back in 2013 (as seen here) when I was new to Digital Storm. That Vanquish is still doing pretty dang well; I definitely made the right choice. So, thanks for having my back once again. See you in 5 years for the next one. |
Quote Reply Posted: 27 May 2016 at 5:25pm |
Our pleasure and Congrats on a real nice rig.
Good choices, the Air 540 and power supply. You're gonna love it. Have fun. |
