Need Bolt X configuration help!
Post Date: 2017-10-24
somedude11 View Drop Down
  Quote somedude11 Quote  Post ReplyReply bullet Topic: Need Bolt X configuration help!
    Posted: 24 Oct 2017 at 5:23am
I've had my ODE Level 4 for about 5 years now, and I absolutely love that it's been rock solid with very little maintenance.  My only complaint is that the case is a bit too big and heavy.
- I'm looking to get a Bolt X replacement and my budget is $3k-$4k.
- I'd like to be able to play Battlefront 2 at max settings.  I also do heavy photo editing.  Would like the same level of longevity in a Bolt X rig that my ODE has had.
2 questions:
1) i7-8700k vs. i7-7800X vs. i9?
2) What kind of maintenance, if any, will I need to perform for the HydroLux liquid cooling?  It looks absolutely fantastic, but if regular maintenance is required than I'd rather just forego this option.
Thanks!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Oct 2017 at 7:01am
Photo editing has use for cores games need only 4.
More cores = more power(multi thread/tasking) but less speed
Less cores = less power higher speeds
So if you want to lean toward editing we go 8 or more cores, if you want to lean towards gaming we go 4 cores.
Middle would be 6 core, each side gives a little.
8700k is top cpu for that line
1. 78xx X is 6 core cpu of x299, this line goes to 16 cores.
So which direction would you like to go?
2. Any lc system can require some work, you can even get a closed aio, but if fan or pump or leak happens you will need to work on it, fan is least likely. For a good oc cooling you need lc here they no longer offer noctua for air.
If you want 4k and max settings you may need sli and bolt doesn't do sli, at least not in configurator
Edited by DST4ME - 24 Oct 2017 at 8:09am
  Quote somedude11 Quote  Post ReplyReply bullet Posted: 24 Oct 2017 at 10:26am
Thanks DST4Me!
These are great suggestions.  I'm leaning towards the 6-core i7-8700k which according to reports, out-performs the i7-7800X.
Do you know if the cooling liquid that DS uses needs to be flushed and changed regularly?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 24 Oct 2017 at 10:42am
Regardless of what the liquid manufacturer says, its always best to flush the system once a year to keep optimal performance.
For the 8700k the h115i should do well, its aio so unless something breaks you don't mess with it.
What res are you going to be gaming at?
Edited by DST4ME - 24 Oct 2017 at 10:44am
FR3SHM3AT View Drop Down
  Quote FR3SHM3AT Quote  Post ReplyReply bullet Posted: 24 Oct 2017 at 3:25pm
Great Build ..
She's going to kick some serious A$$
Congrats and please post review with photos
  Quote somedude11 Quote  Post ReplyReply bullet Posted: 25 Oct 2017 at 10:08am
I think a single slot solution will be fine for me, moreso once the Nvidia Volta based cards arrive.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Oct 2017 at 10:25am
Ok but what res are you gaming at?
  Quote somedude11 Quote  Post ReplyReply bullet Posted: 25 Oct 2017 at 10:43am
1440p now, but upgrading to 4K in the future.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Oct 2017 at 11:09am
How is this? 1762962
You can drop the 1080 ti to a 1080 or 1070 if you want but for 4k 1080 ti would do better
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 25 Oct 2017 at 11:51am
I’m just going to mention what I’ve said in other posts....the Bolt is not that much smaller than other choices, only a couple of inches in length and thinner for example.   The Bolt is actually taller than the Vanquish.    Just mentioning this because the Bolt is a real nice case but is harder to work on and has restrictions on psu and number of video cards and has limited airflow.    It’s thinner design is the main attraction I would think.
Not saying the Bolt is a bad choice, it isn’t.
  Quote Tidgxor Quote  Post ReplyReply bullet Posted: 25 Oct 2017 at 12:56pm
Yeah the Bolt has gotten quite a bit more fat over the years. Hahaha
  Quote somedude11 Quote  Post ReplyReply bullet Posted: 25 Oct 2017 at 8:51pm
That's a good suggestion!  Thanks DST4ME.  I can definitely choose a downgraded video card now while waiting for the new video cards.
Hmm, I hadn't given size much thought, but now you have me thinking about the Velox as an alternative.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Oct 2017 at 10:21pm
Bolt is not my cup of tea either, I like better airflow and more room to work in
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Oct 2017 at 2:22am
The Velox has a right facing window, vs the window being on the left side on most others.    Just be aware in case your desk setup, like mine, prefers left window.
I also have an ODE from 2011 and love it.   It is big.   Heavy I don’t care since it never moves.
Edited by bprat22 - 26 Oct 2017 at 2:32am
  Quote somedude11 Quote  Post ReplyReply bullet Posted: 26 Oct 2017 at 6:17am
Too bad the Lumos doesn't come with a white exterior paint option.  Dimensionally, the Lumos seems like a good alternative to the Bolt X.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 26 Oct 2017 at 6:45am
I agree.   The custom exterior finish available on the Velox has me checking it out, even if it means moving my setup around.  Strong
  Quote FR3SHM3AT Quote  Post ReplyReply bullet Posted: 26 Oct 2017 at 12:18pm
Whatever You End Up With You Are Going To Just Love It In The End..
Digital Storm is kinda like Walt Disney
               Happy Endings
Post Review with lot's of photo's Please
DST4ME ..get your mind out of the gutter...
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Oct 2017 at 3:59pm
HarryK View Drop Down
  Quote HarryK Quote  Post ReplyReply bullet Posted: 04 Nov 2017 at 12:02am
I don't know that airflow would really be an issue unless you're doing serious overclocking and running some heavy duty apps like say, a lot of video rendering. DS does a good job with cable management so not like there's a lot of junk in the way.
That said, yes it is true there's not as much room to work inside a Bolt X compared to a larger case. Personally I like the smaller size, especially compared to my monstrous old case.
