Need help on configPost Date: 2010-08-22 |
Ahyi
Newbie Joined: 22 Aug 2010 Online Status: Offline Posts: 21 |
Topic: Need help on config Posted: 22 Aug 2010 at 7:34am |
Hi, i need help on configuring a new gaming rig. The computer will only be gaming and i have a budget of $3000-$3500, of course if it turns out lower then the budget it be great, but if not I still love it. I'm debating between the ATI HD5970 2GB or GTX 480 1.5GB as for motherboard I was thinking either EVGA x58 classified or the ASUS rampage III extreme. As for cooling I was thinking about water cooling, but not so sure which one would be good enough. I need space for a additional graphics card, because i plan on purchasing a new on by Christmas either a additional gtx480 or ATI 5970
This is what i had in mind Saved Ticket Number: 434618 or 434620 , but since it my first time building a custom pc i thought it be best to ask for some help. Thanks in advance Edited by Ahyi - 22 Aug 2010 at 8:43am |
Ahyi
Quote Reply Posted: 22 Aug 2010 at 7:43am |
Oh and I forgot to add I want something future proof at least for the next 1-2 years. Oh and if it helps my monitor resolution is 1680 x 1050 its a 22' hp monitor. I want to be able to play my games in max setting.
Thanks in advance Edited by Ahyi - 22 Aug 2010 at 7:46am |
teaiewold
Groupie Joined: 26 Jun 2010 Online Status: Offline Posts: 216 |
Quote Reply Posted: 22 Aug 2010 at 10:15am |
Try this ticket number: 434632
you had a lot of uneeded things on that build. Also if you're gaming at 1680x1050 you should be good to go for a while with 1 vid for a while.
rayfinkle
Newbie Joined: 14 Aug 2010 Online Status: Offline Posts: 99 |
Quote Reply Posted: 22 Aug 2010 at 11:23am |
Read the guide that is stickied at the top of the configuration forum. It will answer so much for you.
Otherwise, the pros will be along shortly to answer your questions. |
Ahyi
Quote Reply Posted: 23 Aug 2010 at 9:17am |
thanks for the help guys but you think it be good enough? and future proof? and i wanna add during summer my rooms like a baking oven, so I'm pretty worried about the components. Oh and for the case would you guys recommend the haf x or the haf 932? I myself like the haf x more because of the red lights.... i hate blue I'm sorry... and i thought if i added what games i played it might help, i play WoW, SC2, L4D2, COD MW2, will try out FF XIV, and I play Sims 3 when I'm bored to death.
Edited by Ahyi - 23 Aug 2010 at 9:25am |
!ender_
DS Veteran Joined: 24 Oct 2007 Online Status: Offline Posts: 4219 |
Quote Reply Posted: 23 Aug 2010 at 10:43am |
well the lights and the trim paint can be changed to whatever you want. both the haf 932 and x come all black with 1 red led fan in the bottom front
as far as temps, unfortunately the enviornment is just as important as the hardware cooling, if you have to choose, spend the money on good AC year round over a liquid cooler, both air and liquid cooling depend on the surrounding air temps to cool
between the two cases, just choose whichever you like, the differences are marginal
Ahyi
Quote Reply Posted: 23 Aug 2010 at 11:26am |
i read your sticky i like your last build :D so the air 1 fan from your build would be good enough for my cooling in the case right? oh and i have a ac :D so with that build i should be fine? and for future upgrade within that case i should be all good?
!ender_
Quote Reply Posted: 23 Aug 2010 at 11:39am |
yea both of the haf cases have a lot of room to add future parts if you want to can you link exactly what config you are looking at now? |
Ahyi
Quote Reply Posted: 23 Aug 2010 at 12:03pm |
434632and http://www.digitalstormonline.com/comploadsaved.asp?id=432311 both looks decent
Edited by Ahyi - 23 Aug 2010 at 12:05pm |
!ender_
Quote Reply Posted: 23 Aug 2010 at 12:58pm |
looking pretty good but whats with the huge power supply in the first one
Ahyi
Quote Reply Posted: 23 Aug 2010 at 1:08pm |
im planning to add another 480gtx by Christmas
!ender_
Quote Reply Posted: 23 Aug 2010 at 1:21pm |
i see, well that pretty much brings it down to which case you want
so just pick whichever you like better
