Need Help On First Build. (New to PCs)Post Date: 2017-11-18 |
0mn1p073n7
Newbie Joined: 08 Oct 2017 Online Status: Offline Posts: 9 |
Topic: Need Help On First Build. (New to PCs) Posted: 18 Nov 2017 at 2:24pm |
$3,500 Expectations: Run two monitors, over 60fps with ultra graphics on games. Usage: Streaming, high end gaming, video editing, youtube videos. Special Needs: Be stylish as well...? Saved Ticket #: 1775366 Specifications: Can this setup run two acer predators 2560x1440 at 144hz? I'm not sure how to calculate that or what. Would like some help. I'm also trying to learn this stuff too, so help is apreciated a lot. Thanks in advance. Edited by 0mn1p073n7 - 18 Nov 2017 at 2:26pm |
Quote Reply Posted: 18 Nov 2017 at 6:55pm |
Try this if one 1080ti doesn't cut it for you, you can just add a second for sli
1778701 If your editing stuffcis heavy put ram back at 32gb Edited by DST4ME - 18 Nov 2017 at 6:56pm |
0mn1p073n7
Quote Reply Posted: 18 Nov 2017 at 8:39pm |
Ok thanks, just making sure it was enough.
Quote Reply Posted: 18 Nov 2017 at 9:56pm |
My pleasure its been a while since I have checked out dual monitors, but I'm think you should get 70fps or better with the 1080ti , and the build has enough power to support sli 1080 ti should you need/want it.
Ram is cheap so if you think 32gb is good then go with that Change your case to velox if you can and ask them to put the h155i on top. Edited by DST4ME - 19 Nov 2017 at 12:30am |
0mn1p073n7
Quote Reply Posted: 19 Nov 2017 at 8:26am |
Another question, what would the velox case and the h155i on top do???
Quote Reply Posted: 19 Nov 2017 at 10:50am |
In my experience and others may disagree but I have to go with my experience.
best place to put a rad for cooling is on top so that it sucks the warm air rising right out of the case. some cases here the rad doesn't fit on top so you endup with rad in the front either blowing in warm air and allowing top/rear fans suck it out or rad is in the front sucking air out. the velox will let you put the h115i on top where as lumos might not even fit the h115i and you have to go with older model h110i and it could be in the front. |
