Need help on water cooling optionsPost Date: 2016-04-25 |
wrjohns2
Newbie Joined: 22 Apr 2016 Online Status: Offline Posts: 13 |
Topic: Need help on water cooling options Posted: 25 Apr 2016 at 5:58pm |
I'm trying to decide between the corsair 240mm watercooling option, and the hydrolux PRO (cpu only) option. I'm not sure what the pro's and con's of each are. Which one tends to result in a quieter system? Which one provides better cooling? Are they roughly on par with each other, or does one provide substantially better performance in 1 (or both) of those criteria? |
Quote Reply Posted: 26 Apr 2016 at 3:20am |
Custom watering cooling, as in the Pro, has a stronger pump, usually better radiator and a large reservoir. The Corsair is a sealed All In One unit with much smaller pump and no reservoir. The Pro will keep the CPU cooler, by at least 10c and run quieter because of its flow capacity.
That said, the AIO units will cool the CPU just fine. But, the custom allows for higher overclocking for those interested and quieter. Hope this helps. |
SnowandSand
Groupie Joined: 21 Jan 2013 Online Status: Offline Posts: 278 |
Quote Reply Posted: 26 Apr 2016 at 9:08am |
Unless you plan to water cool the graphics cards also I would probly stick to the AIO cooler.
Hailstorm II(Retired)
R7 2700x 16GB Team Dark Pro @ 3200 CL14 Asus x470 CH VII Hero Corsair Hx1000i 1000W PSU 250GB Samsung 850 EVO 1TB & 6TB WD - Black Edition 2x GTX 980TI Strix Hydrolux Stage 3 |
hoserator
Quote Reply Posted: 26 Apr 2016 at 12:53pm |
The PRO can be configured with different colors and you can add rads and cards later since it is an open loop system and the AIOs are not.
