Need help! upgrading options!
Post Date: 2017-11-07
Stevekjr1186 View Drop Down
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Topic: Need help! upgrading options!
    Posted: 07 Nov 2017 at 1:13pm
Okay so.. I'm not super tech savvy or anything but I get the idea of how everything works pretty well but I'm just curious on what options I have given an 500$ budget on upgrading. I know I want to upgrade to an 8core CPU and I feel like I should do that first before my GPU upgrade.. I'm not sure where at 1050 stands but my games seem to run fine and look pretty good but with the new systems coming out and new games going 4K res soon I want to be as close as possible if I can? Any help would be great. I do have about 550$ saved up for upgrades and I am able to do them myself.
I was thinking of going Amd Ryzen 7 1700 or should I aim higher? I hope this information below will give some idea to what I'm running better than I can explain it.
P.S. I also never over-clocked cpu or gpu ever and not sure exactly how it works or the best way to go about it.
Current Rig via CPU-Z
CPU
AMD FX™-6300 Six-Core Processor
Threading
1 CPU - 6 Core - 6 Threads
Frequency
3499.81 MHz (17.5 * 199.99 MHz) - Uncore: 1999.9 MHz
Multiplier
Current: 17.5 / Min: 7 / Max: 20.5
Architecture
Vishera / Stepping: OR-C0 / Technology: 32 nm
CPUID / Ext.
F.2.0 / 15.2
IA Extensions
MMX(+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Caches
L1D : 16 KB / L2 : 2048 KB / L3 : 8192 KB
Caches Assoc.
L1D : 4-way / L2 : 16-way / L3 : 64-way
TDP / Vcore
94.99 Watts / 1.288 Volts
Temperature
40.3 °C / 105 °F
Type
Retail (Stock Frequency : 3500 MHz)
Cores Frequencies
#00: 3499.81 MHz  #01: 3499.81 MHz  #02: 3799.79 MHz  #03: 3499.81 MHz 
#04: 3499.81 MHz  #05: 3799.79 MHz 
GPU
GPU Type
NVIDIA GeForce GTX 1050 (GP107) @ 721 MHz
GPU Brand
Micro-Star International Co. Lt
GPU Specs
GP107-300 / Process: 14nm / Transistors: 3300M / Die Size: 135 mm² / TDP: 75W
GPU Units
Shader Units: 640 / Texture Units (TMU): 40 / Render Units (ROP): 32
GPU VRAM
2048 MB GDDR5 128 bit @ 810 MHz
GPU APIs
DirectX 12.0 (12_1) / OpenGL 4.5 / OpenCL 1.2 / Vulkan 1.0
Storage (HDD/SSD)
Model #1
TOSHIBA DT01ACA200
Capacity #1
2000 GB
8GB RAM
EVGA 600W PSU
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 6:19pm
Im not an amd fan so I'm not sure if you can upgrade cpu or not.
How much ram do you have?
The higher the res the less cpu comes into play and the gpu becomes more of a factor.
You should only worry about going 4k if you have a 4k monitor otherwise you are wasting your money.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 6:22pm
Again I'm no amd expert but after a quick look I think you won't be able to upgrade your cpu, looks like different socket which means new mobo
Edited by DST4ME - 07 Nov 2017 at 6:23pm
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 6:56pm
Really? What makes you think I can't change my CPU? Fan has the clamps and I was told I would be able to when I built it so I hope so 😂. Right now my my ram is 8gb it would be a bummer to have to get a new mobo if I did I'd probably go intel anyway from what I've been reading
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 7:50pm
Well im no amd expert so maybe I'm wrong but your cpu is socket amd3 new cpu is amd4, if those 2 are compatible then you can upgrade, I'm assuming they are not.
I would go 16gb ram, that would be my first update but see about the cpu first.
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:14pm
I looked into it as well and looks like this may be the case. So I guess a mobo first will be the first thing 😂 Any suggestions?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:26pm
Ya intel
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:28pm
So Ryzen is am4 then correct? That was actually something that didn't cross my mind at all. I can probably atleast work in an amd fx8350 pretty sure that's AM3 if I'm not mistaken.. wouldn't overheat this mobo would it?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:33pm
If the socket match your current cooler should do the job, worst case scenario you get a new cooler. But no it wouldn't overheat the mobo, its the cpu itself that would overheat.
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:43pm
Awesome. I just want to stay on par with consoles until I'm finished with school next year and then worry about doing what I can for the best pc I can imagine. And yes I actually have a 4K monitor. Was a gift from my wife. It's what made me think of upgrading. Good call though before I wasted my money.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:47pm
Well you can upgrade gpu but you will probably need sli 1080 ti for 4k, plus a psu upgrade, in short forget that.
Maybe just wait
Edited by DST4ME - 07 Nov 2017 at 9:48pm
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:49pm
1080 won't bottle neck with my processor?
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:51pm
Crap didn't read that correctly. Yeah psu needs an upgrade anyway. Thanks for all the help.
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:53pm
Any suggestions on psu? Seen an 850w corsair psu on new egg earlier for like 90$?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:55pm
There might be some bottleneck, one of the reasons why it's not worth it then there is the cost plus cost of psu upgrade = not worth it
My pleasure, sorry I'm not well informed in amd so I could not provide better info.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:57pm
Go full module go gold or better, in corsair stay in hx and ax models, good quality great warranty
Your current psu can handle a single 1080
Edited by DST4ME - 07 Nov 2017 at 9:58pm
  Quote Stevekjr1186 Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 9:59pm
Gotcha. And np on the amd stuff. I'm still learning it all myself. Built mine a few years back still runs games pretty well. Take care appreciate it
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Nov 2017 at 10:00pm
Good luck
