Need inputPost Date: 2016-05-08 |
Democules
Groupie Joined: 06 May 2016 Online Status: Offline Posts: 158 |
Topic: Need input Posted: 08 May 2016 at 10:34pm |
8-10k Expectations: To be blown away Usage: High end gaming Special Needs: I game for a living so Ok, so I am starting over, I think I have approached this from the wrong angle. I want the fastest cleanest sweetest set up I could possibly ever want or need for "Elite Gaming" I think I was over investing in many areas due to a lack of understanding about the technology and what gaming pushes and needs to be pristine. I plan on using the Asus ROG Swift 34inch PG348Q g-sync at 3440x1440 I need one open extra pci-e slot for my wireless adaptor I plan on using a pci-e solid state drive I plan on using 2 or more GTX-1080's when they launch at the end of the month. how much ram? and how fast? I-7? Intel or Samsung on the solid state pci-e drive? how many videos cards? Sound Card? is there a need? what would justify having one? If so, which one do I want? what level of cooling? what size power unit? how important is a raid set up to me as a gamer? if so how and what do I need to do? I had planned on the Aventum 3 Chassis, however I am open to suggestions as long as they come with an explanation. PLEASE help me ASAP! hehe I want to order as soon as the 1080's launch Edited by Democules - 09 May 2016 at 6:01pm |
hoserator
Quote Reply Posted: 09 May 2016 at 1:08am |
Hi Democules,
Welcome to DS. A word of warning, the Aventums are very HUMONGOUS. You will need space where to put it. They only ship via freight. Others will post on the technical pros and cons of what you have listed. They will advise in order to determine the optimum mix of parts. I can tell you that the noise suppression package is not needed, nor the wireless adapter or sound card. Happy shopping. |
Quote Reply Posted: 09 May 2016 at 2:59am |
What to say, the build is a monster.
Unless you'll be streaming and recording while gaming, I wouldn't think the 8 core is needed. Also, the 1500 watt is lots more than you need. In a couple of weeks the new Pascal cards will be released. I'd wait and see what they offer, the rumor being the new gtx 1080 will be faster than the 980 ti by about 25% and less power needed. Good luck. |
Democules
Quote Reply Posted: 09 May 2016 at 7:01am |
I had thought the sound dampening would be a big deal, it has been 7 years since I had money for a nice system, but my last one was soooo noisy.
I am glad you mentioned the power supply, I went with the extreme pre-made build and tweaked it. I am not very knowledgable about hardware anymore, I just research and read a lot when it's time to buy. Edited by Democules - 09 May 2016 at 4:12pm |
Quote Reply Posted: 09 May 2016 at 7:58am |
I don't do much with audio, so maybe others can give better advice, but most find the onboard audio very good, unless you have a high end audio setup. Mobo audio has improved a lot over the last several years.
A 1000watt psu should do it for an sli setup. I don't believe that WS mobo you selected has built in WiFI. You'd need the Deluxe for that. Edited by bprat22 - 09 May 2016 at 8:04am |
Democules
Quote Reply Posted: 09 May 2016 at 4:08pm |
hehe, I actually started a thread on the gtx 1080 a couple days ago, I have my eye on them thanks for the heads up on the processor too |
Democules
Quote Reply Posted: 09 May 2016 at 4:11pm |
right on, the wifi card came with the router when I bought it, so I might as well put it to good use as far as the sound goes, yea I have no clue, I liked the accessibility of the external audio control module... |
db188
Quote Reply Posted: 09 May 2016 at 5:07pm |
Aventum 3
Democules
Quote Reply Posted: 10 May 2016 at 6:27am |
Thanks man, some good info.
Democules
Quote Reply Posted: 10 May 2016 at 2:44pm |
Chassis
Chassis Model: Aventum 3 Exterior Finish: Black Metallic Matte Finish Core Components Processor: Intel Core i7 5930K 3.5GHz (Six-Core) (Unlocked CPU) Motherboard: ASUS X99-A USB 3.1 (Intel X99 Chipset) (Up to 4x PCI-E Devices) System Memory: 16GB DDR4 3000MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Storage / Connectivity Optical Drive: Blu-Ray Player/DVD Writer (Play Blu-Ray and Burn DVDs) (Internal) Storage Set 1: 1x SSD M.2 (512GB Samsung 950 PRO) (NVM Express) (Extreme Performance) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics / Multimedia Graphics Card(s): 1x - No Thanks Sound Card: Creative Sound Blaster Zx (Includes Audio Control Module) Digital Storm Engineering Extreme Cooling: H20: HydroLux PRO: Exotic Custom Cooling System (2x Graphics Cards + CPU) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Blue Fluid (Requires HydroLux Liquid Cooling System) Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair LED Airflow Performance Edition (Blue) (Up to 6 Fans) Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Digital Storm TwisterBoost Technology Boost Processor: Stage 2: Overclock CPU - Up to 4.8GHz (Depends on Cooling and Motherboard) Boost Graphics Card(s): Yes, Overclock the video card(s) as much as possible with complete stability Boost OS: Yes, Disable and tweak all of the non-crucial services on the operating system Software Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Accessories / Goodies Customer Care Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) So, I will be adding dual GTX-1080's when they launch. I really would like feedback on my processor / motherboard choice (more motherboard) I downgraded the choice it offered and wondering whether I made a good choice. Edited by Democules - 17 May 2016 at 12:27pm |
Democules
Quote Reply Posted: 17 May 2016 at 12:31pm |
I think Dual GTX-1080's will run anything I could want no?
So, I will be adding dual GTX-1080's when they launch. I really would like feedback on my processor / motherboard choice (more motherboard) I downgraded the choice it offered and wondering whether I made a good choice. Edited by Democules - 17 May 2016 at 12:43pm |
Quote Reply Posted: 17 May 2016 at 2:47pm |
I'll comment a bit on your CPU/ mobo choice. You mentioned 2 or more gtx 1080 and for that the X99 platform with the 5930 k would be my choice. The 5930k has 40 Pcie lanes for graphics giving you a full x16 lanes per card in sli. The 5820k has only 28 lanes. Now, x8 lanes to a video card is all you need at the present time, but can't say a few years from now.
The z170 and 6700k can also sli but not tri Sli. Nothing wrong with z170 for single or sli. But lanes to the CPU for more cards and storage is in the x99. As far as the mobo..... You'd have to read up on the specs of each and see if one has features you want the others don't. Generally, the x99-a is fine. The higher end boards have more overclock potential and tools for the over locker to use. Onboard WiFi/ Blutooth, Pcie lane disable switches to isolate cards without removing them, etc are all considerations. Your picks look good. |
Democules
Quote Reply Posted: 17 May 2016 at 3:12pm |
Sweet, Thx Bprat. I actually just talked to someone for a while on the phone and clarified some things, but I like hearing that I am on the right track from multiple sources. Especially when dropping 7k on a pc hehe.
I am on the Asus website doing side by sides on some mobos now. I am enjoying the research, but sometimes having someone there to explain things goes a long way. |
Democules
Quote Reply Posted: 26 May 2016 at 10:58pm |
So, order completed! This is what I ended up with 😀 System Configuration: Chassis Model: Special Deal Hot Seller - Aventum 3 Exterior Finish: Black Metallic Matte Finish Trim Accents: - Not Available Processor: Intel Core i7 5930K 3.5GHz (Six-Core) (Unlocked CPU) Motherboard: ASUS X99 RAMPAGE V USB 3.1 (Intel X99 Chipset) (Up to 4x PCI-E Devices) System Memory: 32GB DDR4 2800MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 1000W Corsair HX1000i (Digitally Controlled Power) Expansion Bay: Option Not Available Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) (Internal) Storage Set 1: 1x SSD M.2 (512GB Samsung 950 PRO) (NVM Express) (Extreme Performance) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 2x SLI Dual (GeForce GTX 1080 8GB (NVIDIA Founders Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux PRO: Exotic Custom Cooling System (2x Graphics Cards + CPU) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Blue Fluid (Requires HydroLux Liquid Cooling System) Cable Management: Exotic Cable Management - Blue - (Cable Combs with Custom Color Sleeved Extension Cables) Chassis Fans: Corsair LED Airflow Performance Edition (Blue) (Up to 6 Fans) Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Stage 2: Overclock CPU - Up to 4.8GHz (Depends on Cooling and Motherboard) Graphics Boost: Yes, Overclock the video card(s) as much as possible with complete stability OS Boost: Yes, Disable and tweak all of the non-crucial services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Quote Reply Posted: 27 May 2016 at 2:12am |
Congrats and one awesome rig.
db188
Quote Reply Posted: 27 May 2016 at 2:39am |
Aventum 3
hoserator
Quote Reply Posted: 27 May 2016 at 5:43am |
Awesome EnjoyThat is one big boy.
Edited by hoserator - 27 May 2016 at 6:20am |
Democules
Quote Reply Posted: 27 May 2016 at 11:36am |
NOOOOOOOOZ!!!! They are out of Aventum 3's. I have to wait until the end of June before they can even start...Cry...I waited a month for the 1080's now this ugh.
Jason was really cool and helpful btw - big props I had a potentially huge issue with my order (payment screw up on my part) and Jason kicked ass and took names got it cleared up and kept me from ending up in a big financial mess lol! |
