Need some advice on my build
Post Date: 2014-12-31
Amasian View Drop Down
  Quote Amasian Quote  Post ReplyReply bullet Topic: Need some advice on my build
    Posted: 31 Dec 2014 at 4:42pm
under 4000
To run most new games at 1080p
To play Far cry 4 and other games like evolve when it comes out
Saved Ticket #: 1124746
Processor
optionIntel Core i7 4790K 4.0 GHz (Codename Devils Canyon) (Unlocked CPU) (Quad Core)
More Info
CHANGE
Motherboard
optionASUS Z97-DELUXE (Intel Z97 Chipset) (Features 802.11ac Wi-Fi Connectivity)
[+$196]
More Info
CHANGE
System Memory
option16GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested)
More Info
CHANGE
Power Supply
option750W Corsair CX750M
More Info
CHANGE
STORAGE / CONNECTIVITY
Expansion Bay
option- No Thanks
CHANGE
Optical Drive
optionDVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x)
More Info
CHANGE
Storage Set 1
option1x Storage (2TB Western Digital - Enterprise Edition)
[+$92]
More Info
CHANGE
Storage Set 2
option1x Storage (1TB Seagate)
More Info
CHANGE
Storage Set 3
option- No Thanks
CHANGE
Set 1 Raid Options
option- No Thanks
CHANGE
RAID Card
option- No Thanks
CHANGE
Internet Access
optionHigh Speed Network Port (Supports High-Speed Cable / DSL / Network Connections)
More Info
CHANGE
MULTIMEDIA
Graphics Card(s)
option1x NVIDIA GeForce GTX 980 4GB (Includes PhysX)
More Info
CHANGE
Sound Card
optionIntegrated Motherboard Audio
More Info
CHANGE
HPC Processor
option- No Thanks
CHANGE
ENGINEERING
Hydrolux Cooling. Learn more.
Extreme Cooling
optionH20: HydroLux Level 1: Digital Storm Exotic Custom Cooling System (CPU Only)
[+$524]
More Info
CHANGE
H20 Tube Color
optionGreen Tubing with High-Performance Fluid (UV Lighting Reactive)
[+$0]
More Info
CHANGE
Airflow Control
option- No Thanks
CHANGE
Internal Lighting
optionInternal Chassis Lighting System (Green)
[+$10]
More Info
CHANGE
Chassis Fans
optionUpgrade Chassis With LED Performance Fans (Green) (Up to 6 Fans)
[+$59]
More Info
CHANGE
Chassis Mod's
option- No Thanks
CHANGE
Noise Reduction
option- No Thanks
CHANGE
LaserMark
option- No Thanks
CHANGE
OVERCLOCKING
CPU Boost
optionStage 1: Overclock CPU 4.0GHz to 4.4GHz
More Info
CHANGE
Graphics Boost
optionYes, Overclock the video card(s) as much as possible with complete stability
[+$45]
More Info
CHANGE
Memory Boost
option- No Thanks, Please do not overclock my memory
CHANGE
OS Boost
optionYes, Disable and tweak all of the non-crucial services on the operating system
[+$35]
More Info
CHANGE
SOFTWARE
Windows OS
optionMicrosoft Windows 7 Home Premium (64-Bit Edition)
[+$0]
More Info
CHANGE
Recovery Tools
optionWindows Recovery Toolkit (Bundled with Windows CD)
More Info
CHANGE
Virus Protection
optionFREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value)
More Info
CHANGE
Office Suite
option- No Thanks
CHANGE
Game
option- No Thanks
CHANGE
ACCESSORIES
Branded Gear
option- No Thanks
CHANGE
Display
optionAsus 27 inch Professional PB278Q (2560 x 1440) (100% sRGB) (WQHD LED Backlight)
[+$629]
More Info
CHANGE
Surge Protector
option- No Thanks
CHANGE
Audio
option- No Thanks
CHANGE
Keyboard
option- No Thanks
CHANGE
Mouse
option- No Thanks
CHANGE
NVIDIA SHIELD
option- No Thanks
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 Jan 2015 at 6:53am
Hi Amasian... Welcome to the forums.     Looks like a good build to me. Drooling
The gtx 980 will give you excellent gaming on the 1080p you mentioned or the 2560x1440 monitor you listed in the config.
Good luck and keep us updated. Big%20Smile
