No connection through EthernetPost Date: 2016-03-21 |
21QZ
Newbie Joined: 28 May 2015 Online Status: Offline Posts: 33 |
Topic: No connection through Ethernet Posted: 21 Mar 2016 at 11:31am |
Man ..
I have been having some odd problems lately. Recently I have switched routers and since then I have been using Wifi because when I connect by Ethernet cord and it seems like it knows its there, but it doesn't connect? Anyone willing to provide steps I can try when I get home from work today? Really Appreciate it, |
carefulpunch
Groupie Joined: 03 Mar 2016 Online Status: Offline Posts: 157 |
Quote Reply Posted: 10 Jul 2016 at 9:08pm |
There are probable causes of an ethernet problem but the common is caused by a network issue or a cable or hardware issue and other antivirus or firewall. You may check all of those I mentioned to find a better solution.
Edited by carefulpunch - 10 Jul 2016 at 9:12pm |
carefulpunch
Snaike
Quote Reply Posted: 10 Jul 2016 at 11:36pm |
I feel your pain.. I went through this for awhile and was certain that it was the computer malfunctioning.
I called the cable/ISP company and they came out, changed the router, and it was all good. Good luck! |
Quote Reply Posted: 10 Jul 2016 at 11:49pm |
As Snaike mentioned it can be your router, if you can first try a different Ethernet cord from pc to router, if that does not work next try connecting the lan to a different computer with the new Ethernet cord and if there is still the same issue on the new pc/laptop then it is the router.
that is assuming your router is properly setup. Edited by DST4ME - 10 Jul 2016 at 11:49pm |
