No video and flickering. HELP :(Post Date: 2013-12-02 |
cherryb
Newbie Joined: 02 Dec 2013 Online Status: Offline Posts: 2 |
Topic: No video and flickering. HELP :( Posted: 02 Dec 2013 at 10:48pm |
I just received my rig and there is nothing on my monitor. I've tried HDMI, DVI, VGA, different monitors, a television... Now I'm getting flickering, like its trying to read it. Now my keyboard and my mouse are flickering with it :/ I really don't know what I'm doing but all I want to do is play it and I was all excited and now I'm just super let down. Any help would be GREATLY appreciated.
:C |
Ariktu
Groupie Joined: 21 May 2013 Online Status: Offline Posts: 492 |
Quote Reply Posted: 02 Dec 2013 at 10:50pm |
Did you try reseating the video card?
What system do you have since someone with that system might have more information. I also assume you are using the video card and not the MB onboard video. |
cherryb
Quote Reply Posted: 02 Dec 2013 at 11:09pm |
I tried reseating it but its so compact! I have the bolt. I also disconnected to run off the MB and when I did that it didn't do anything, just a blank screen and no flicker.
Thanks for the quick reply! |
Quote Reply Posted: 03 Dec 2013 at 2:51am |
It sounds like a bad video card. But, could be other issues. The card connects to the motherboard with a ribbon cable that needs reseating both at the card and the motherboard. Both ends. It is a tight fit. The mobo gpu ports will only work with video card unplugged from the system. Try reseating the ram sticks and all the connectors to the mobo.
Good luck. |
