no video signal after installing liquid coolingPost Date: 2016-05-14 |
funeralpyre88
Groupie Joined: 04 Feb 2011 Online Status: Offline Posts: 170 |
Topic: no video signal after installing liquid cooling Posted: 14 May 2016 at 3:15pm |
I lost faith in my old post so I'm starting a new one. I have a core [email protected] with a GTX 980 Ti Strix in an Apollo case with 16 GB 2800MHz ram and asus z170 motherboard. My cpu and gpu are hooked up to a Predator 360 liquid cooling system, brand new.
Recently I installed predator 360 cooling systems, upon successfully installing it, i turned on the computer, but there is no video signal. The keyboard and mouse lights are flashing, I can tell the liquid pump is moving. How do I restore the video? Thanks. |
core i7-6700k @4.7 GHz
Predator 360 cpu&gpu 16 GB DDR4@2800 MHz ASUS Z-170 PRO GAMING 256 GB SAMSUNG 850 PRO 500 GB SAMSUNG 850 EVO GTX 980 TI ASUS STRIX ACER XB270HU 2560x1440 @144 hz |
Quote Reply Posted: 14 May 2016 at 3:33pm |
Tough to say from here, but check that the Strix is seated correctly and its power cables from the psu are hooked up right.
funeralpyre88
Quote Reply Posted: 14 May 2016 at 3:38pm |
i see 2 8-pin power connectors on the gpu, i think those are the only ones... unless i'm forgetting something. I think i'm going to try unseating the gpu and booting from motherboard video to see what happens, because that's worked before when I had this problem.
Quote Reply Posted: 14 May 2016 at 3:40pm |
That was my next check. That way you can check that Windows is booting ok and everything else is working.
funeralpyre88
Quote Reply Posted: 14 May 2016 at 3:54pm |
I removed the video card and plugged the monitor cable into the mb, turned on computer, still nothing. The hard drives are all plugged in.
hoserator
Quote Reply Posted: 14 May 2016 at 4:02pm |
Can you check the monitor somewhere else to make sure it works? Very rare for it to go at this time but......
Quote Reply Posted: 14 May 2016 at 4:06pm |
Are the case fans turning on ? Is the PWR ready led on bottom of mobo lit?
Check the 8 pin plug above the CPU and 24 pin plug on the right for being seated correctly. Can you check the monitor elsewhere, or use a different cable ? Any chance you have an older video card you can try ? Without knowing what you did, this is all guess work. |
Nomad1970
Senior Member Joined: 23 Feb 2013 Online Status: Offline Posts: 716 |
Quote Reply Posted: 14 May 2016 at 4:27pm |
Are you sure you have the monitor set to the correct cable intput?
Edited by Nomad1970 - 14 May 2016 at 4:28pm |
My Precious 2
I7-9700 oc 4.7GHz 32GB DDR4 3000MHz Corsair Vengeance RGB Pro SSD M.2 (512GB Samsung 970 PRO) SSD M.2 1TB Samsung 970 EVO 240GB Samsung 860 Pro SSD 1TB W.D. HD EVGA GTX 1080Ti |
funeralpyre88
Quote Reply Posted: 14 May 2016 at 4:39pm |
yes, all the case fans are turning on. yes, the pwr ready led is lit. all the pins and plugs are connected and seated correctly. i tried another monitor, still does not work. I don't have any other video cards i can try.
funeralpyre88
Quote Reply Posted: 14 May 2016 at 4:42pm |
I did leave some thermal paste around the gpu core, (the green circuit board part) without cleaning it up, i hope that didn't damage anything? I hope i didn't excessively touch the gpu too much when I was putting the waterblock on it.
funeralpyre88
Quote Reply Posted: 14 May 2016 at 4:47pm |
although I do remember I accidentally made a tiny scratch on the video card, the very outer edge. It didn't even look like there was anything important on that part of the video card, but perhaps that damaged it somehow?
