PC Fan QuestionPost Date: 2017-01-04 |
Auramyst
Newbie Joined: 03 Jan 2017 Online Status: Offline Posts: 4 |
Topic: PC Fan Question Posted: 04 Jan 2017 at 12:28am |
Will DigitalStorm put the max amount of fans the case can fit if I select an option from the list of fans that aren't the standard chassis fans?
#1579070 |
Quote Reply Posted: 04 Jan 2017 at 2:17am |
They use to just replace existing fans but, last I heard, they use all the fans in the option package, if there are spots for them. Ask them to make sure.
FrankW
Quote Reply Posted: 04 Jan 2017 at 10:01am |
Hi Auramyst,
It may vary by what fans you buy. They use to say x number of fans but most options don't say that anymore. I see the Thermaltake Ring fangs are a pack of 3. So for your money I guess you get three fans. It is not clear at all and I would follow bprat22's suggestion and contact DS sales for clarification. Frank |
Quote Reply Posted: 04 Jan 2017 at 10:29am |
Hi Frank..Happy New Year... Good point with the fans. I just checked for the first time in awhile and they did drop the "up to 6 fan" mention. Not sure what they do now.
FrankW
Quote Reply Posted: 04 Jan 2017 at 12:57pm |
Hi bprat22,
Thanks for the New Year wishes. The same back at you. Yes they have dropped the 6 fan option. Maybe Alex can fill us in on the new proceedure. Frank |
Alex
Quote Reply Posted: 05 Jan 2017 at 9:29am |
Yes, we will try to maximize the amount of fans, that' why we don't say up to 6 no more.
