Performance Spikes And GTX making a bit of Nose.Post Date: 2016-10-24 |
GamerWolfOps
Newbie Joined: 26 Jun 2016 Online Status: Offline Posts: 36 |
Topic: Performance Spikes And GTX making a bit of Nose. Posted: 24 Oct 2016 at 12:33am |
vanquish 5 Level 2.
Ok i have not being worried for the past few weeks i had no major issues till now when i play some of my games in high end settings the GTX card starts to make some loud nose and of course the CPU memory spikes the Performance goes above 50%. What should i do in this case? anyone have any ideas? should i clean the video card? Edited by GamerWolfOps - 24 Oct 2016 at 12:35am |
GamerWolfOps
Quote Reply Posted: 24 Oct 2016 at 1:12am |
The only game causing this amount of pain for the
Performance Spikes is far cry primal.
Edited by GamerWolfOps - 24 Oct 2016 at 1:13am |
hoserator
Quote Reply Posted: 24 Oct 2016 at 1:19am |
Keep the inside and fans clean of dust. Download HWMonitor to check your temps.
The gpu should be running below 80C at full load. The noise could be many things, fan noise (air), fan blades hitting something, or coil whine. Others will probably give you more detailed advise as to the noise but cleaning is a must. Also post the model card and details of your system so the more knowledgeable are able to identify other possible issues causing the noise. Main thing is to monitor temps. Edited by hoserator - 24 Oct 2016 at 1:20am |
Quote Reply Posted: 24 Oct 2016 at 2:41am |
Follow hoserator 's advice.
Some custom, multi fan cards have fans that only kick on at a particular temperature, like 64c for example. Is that when the noise starts ? Some noise is normal when the fans kick on with certain manufacturers. My MSI is quiet when they kick on but not so in all cases. Sounds like a bad fan if it's loud. |
GamerWolfOps
Quote Reply Posted: 24 Oct 2016 at 4:31am |
Vid Card:GeForce GTX 1060 6GB
Intel 7 6700 CPU 3.40GHz 8GB Memory. 1TB Thats all main parts. "Sounds like a bad fan if it's loud." Not really loud just minor but still a bit though. |
Quote Reply Posted: 24 Oct 2016 at 5:00am |
Graphics card fans are typically the loudest part of rig under stress. If your is the reference single fan type, then it will be louder than some of the custom cards.
db188
Quote Reply Posted: 26 Oct 2016 at 1:07am |
Far Cry primal on High settings is going to push your hardware. what type of "sounds" are you hearing from your card? can you explain it. does it sound like a hair dryer from the blower cooler pushing out all of that hot air? does it sound like a high pitched whine? is it a "ticking" sound?
Aventum 3
db188
Quote Reply Posted: 26 Oct 2016 at 1:30am |
as for your cpu performance, this game has bad multi-core scaling, so you'll see a single core maxed out while the rest don't do much. try disabling hyper-threading on your cpu, it might (depends on game) improve performance.
your 1060 is probably being bottle-necked as well if you're playing at 1080p res. try increasing the resolution if possible and turn up the graphics settings in order to shift more to the gpu side of things-you have 6GB of VRAM on that card so you should be fine. what you really need is a k-model proc that can increase its frequency. |
Aventum 3
Quote Reply Posted: 26 Oct 2016 at 2:23am |
Never played Primal, but the FarCry series has proven to be the toughest on my graphics cards. It just drives them hard.
