Power SupplyPost Date: 2017-09-20 |
Darkdrium
Newbie Joined: 30 Nov 2016 Online Status: Offline Posts: 2 |
Topic: Power Supply Posted: 20 Sep 2017 at 8:18am |
So the power supply on my bolt 3 shorted out and I need to replace it. I want to get something that is between 500-750w and is modular so can anyone give me an exact model I can buy at best buy or amazon?
Chassis Model: Special Deal Hot Seller - Pre-built Digital Storm Bolt 3 Exterior Finish: Black Brushed Aluminum Hairline Finish Side Window: Edge to Edge Premium Acrylic Processor: Intel Core i5 6600K 3.5GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170I PRO GAMING (Intel Z170 Chipset) (Mini-ITX) (Up to 1x PCI-E Device) System Memory: 8GB DDR4 2666MHz Digital Storm Performance Series Power Supply: 400W Digital Storm Performance Series (Supports up to GTX 1070) Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) (Internal) Storage Set 1: 1x SSD (480GB Digital Storm Performance Series) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1070 8GB (EVGA ACX 3.0) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: Digital Storm HydroLux PRO (CPU + Graphics Card) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Red Fluid (Requires HydroLux Liquid Cooling System) Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Black 120mm Fans Internal Lighting: Software Controlled Internal + Front Panel RGB LED Lighting (Requires Airflow Control Upgrade) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks CPU Boost: Standard Intel Turbo Boost 2.0 Automatic Overclocking Graphics Boost: - No Thanks, Please do not overclock my video card(s) OS Boost: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Factory Reset Feature (Restore Windows + Drivers) (Partition up to 25GB of Storage) |
Quote Reply Posted: 20 Sep 2017 at 8:23am |
If it fits in your case, look at corsair 750w hx or hxi, they are both great and should be fully modular.
Darkdrium
Quote Reply Posted: 20 Sep 2017 at 8:55am |
Yeah not to sure what the max size psu will fit in there that is why I'm asking here
Quote Reply Posted: 20 Sep 2017 at 9:08am |
What is the current psu size? I don't own one so I'm not sure.
Now they have the x which is bigger so i can't compare. Bp or db should know, one of them will let us know If you can give us current psu dimensions we could figure it out Edited by DST4ME - 20 Sep 2017 at 9:13am |
Quote Reply Posted: 20 Sep 2017 at 9:40am |
I believe the Bolt family can only accomodate an SFX size psu, somewhat smaller than the typical size.
Lian Li has a 750 watt SFX, the PE-750 that should do it. Silverstone also has SFX size boxes on Amazon, 600 and 700 watt. You could double check with DS just to make sure. Check the dimensions of what you have and compare would be the best advice if getting in touch with DS doesn't work because of work, busy, etc. |
Quote Reply Posted: 20 Sep 2017 at 9:44am |
There's also the SFX-L, which is a longer supply to accommodate a larger cooling fan, 80mm to 120mm, which is good. . That should fit also.
db188
Quote Reply Posted: 20 Sep 2017 at 8:05pm |
their new Bolt supports SFX and SFX-L, but i'm not sure on the previous gen's.
Aventum 3
