Preliminary build helpPost Date: 2017-04-18 |
Alci
Groupie Joined: 16 Apr 2010 Online Status: Offline Posts: 250 |
Topic: Preliminary build help Posted: 18 Apr 2017 at 8:41am |
I'll be using a predator x34 monitor. How is this build?
https://www.digitalstorm.com/configurator.asp?id=1649023 |
Quote Reply Posted: 18 Apr 2017 at 8:53am |
If this is a gaming rig you don't need the 6850K cpu, 32gb ram or sli 1080ti. The 6850k might be needed if you stayed with sli because of your M.2 drive, , but otherwise, not needed.
The 6800k cpu, or even better, the 7700k, 16gb ram and a single video card are all you need to run an ultra wide 1440p display. Configuration Code: 1649027 Total Price with Instant Savings: $3,606.00 Direct Load URL: https://www.digitalstorm.com/configurator.asp?id=1649027 Specifications: Chassis Model: Special Deal Hot Seller - Hailstorm II Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6800K 3.4GHz (6-Core) (Unlocked CPU) <br><strong></strong> Motherboard: ASUS X99-A II (Intel X99 Chipset) (Up to 4x PCI-E Devices) System Memory: 16GB DDR4 3000MHz Digital Storm Performance Series <br><strong></strong> Power Supply: 850W EVGA SuperNOVA <br><strong></strong> Expansion Bay: Option Not Available Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD M.2 (500GB Samsung 960 EVO) (NVM Express) Storage Set 2: 1x SSD (480GB Digital Storm Performance Series) Storage Set 3: 1x Storage (3TB Seagate / Toshiba) RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1080 Ti 11GB (NVIDIA Founders Edition) (VR Ready) <br><strong></strong> Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H115i - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows 10 Installation CD Only (Clean Install with No Drivers) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Alci
Quote Reply Posted: 26 Apr 2017 at 10:28am |
This case has a total of 15 fan slots according to the description. Assuming I wanted them all filled with fans, what would be the additional cost and how do I select this option?
