rad/fan questionPost Date: 2014-03-02 |
kernols
Groupie Joined: 27 Jan 2009 Online Status: Offline Posts: 248 |
Topic: rad/fan question Posted: 02 Mar 2014 at 4:44pm |
Currently im using a 240 thick rad with two typhoons 1850 rpm pulling air in to cool a 3630k. i wanted to mess around with adding 2 fans inside the case on the rad to make it push pull. problem is, the room between the rad and the motherboard is much slimmer than a standard 120mm fan. so there are slim ones out there but which rpm/cfm fan should i go with. something slower or faster than the gt's. i was reading slower rpm, is that correct?
