Reset BIOS, is DS able to give info on my OC?Post Date: 2013-02-18 |
Belly
Newbie Joined: 21 Sep 2010 Online Status: Offline Posts: 10 |
Topic: Reset BIOS, is DS able to give info on my OC? Posted: 18 Feb 2013 at 2:03pm |
Hello,
If this is in the wrong forum, I apologize. Recently, I had installed Ubuntu for a while on a new partition. After deciding I didn't want to use it anymore, I removed the partition. Since I'm horrible with keeping things simple for myself, I had run into some boot issues and had reset BIOS settings without really needing to. That said, my OC settings have disappeared (I know, I should have written them down beforehand; except I did write down Target CPU Frequency, Target Memory Frequency, CPU Clock Ratio, and CPU Host Frequency - I didn't delve too deeply into other BIOS settings and I know they're just as important). Everything else is back to normal though. Is DS able to give me the BIOS info on the OC they performed when I bought my PC? I can forward my product information to an employee via e-mail if need be. Any help is greatly appreciated! |
Quote Reply Posted: 18 Feb 2013 at 2:07pm |
DS does save the oc in a seperate profile in Bios. Select and load it should restore oc. If its gone, call or email DS and they will send you the settings they keep on file.
Good luck. |
Quote Reply Posted: 18 Feb 2013 at 2:10pm |
As mentioned your oc profile is saved in the bios, not sure what mobo you have but go in to power or voltage section of the bios and you should see "save" and "load" for profiles, load profile #1 and that should be your oc.
Belly
Quote Reply Posted: 18 Feb 2013 at 2:13pm |
Excellent! That worked perfectly.
Thanks!! |
Quote Reply Posted: 18 Feb 2013 at 2:14pm |
Our pleasure and good luck
Quote Reply Posted: 18 Feb 2013 at 2:19pm |
Nice. Enjoy.
