Subzero liquid cooling stage 3 question
Post Date: 2012-05-21
tybalt View Drop Down
Avatar
  Quote tybalt Quote  Post ReplyReply bullet Topic: Subzero liquid cooling stage 3 question
    Posted: 21 May 2012 at 4:43pm
I was wondering what fluid ds uses? Do they put any add ins like Swiftech hydrx or Fluidxp? I heard that adding these to your liquid cooling system helps reduce the wear and tear on the system
Intel Core i7 3770K 4.5 GHz
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
(120GBSSD 1TB hard drive)
NVIDIA GeForce GTX 670 2GB (Overclocked EVGA)
Avatar
Digital Storm Live Chat Rep.
  Quote Asangard Quote  Post ReplyReply bullet Posted: 21 May 2012 at 7:34pm
Hi tybalt
DS uses Feser One Cooling Fluid.  It contains ethylene glycol.  Here is a quote from the bottle. "Ready to use anti-corrosion fluid.  Protects copper, aluminium, brass and nickel."  Then it says: "Do not mix with other liquids".
I hope that helps.
Avatar
  Quote tybalt Quote  Post ReplyReply bullet Posted: 21 May 2012 at 8:07pm
Thanks asan! Exactly what I was looking for. Just wanted to make sure it wasn't just water. Thanks again
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 21 May 2012 at 11:15pm
Nope, no water. Big%20Smile
Avatar
  Quote tybalt Quote  Post ReplyReply bullet Posted: 22 May 2012 at 12:10am
One last question about it... Does anyone know the maintenance on it? Do you have to flush it? Will I have to add more fluid later? Thanks again alex and asan
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
surf71zx View Drop Down
Avatar
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 22 May 2012 at 7:00am
Its recommended to be done every 3 years. Your fluid levels do drop.Order a bottle of the Feser and they will send it with your computer.
Avatar
  Quote tybalt Quote  Post ReplyReply bullet Posted: 22 May 2012 at 10:07am
Good to know! I'll set a reminder when I get my comp. Want this thing to last! Thanks surf
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
FR3SHM3AT View Drop Down
Avatar
  Quote FR3SHM3AT Quote  Post ReplyReply bullet Posted: 22 May 2012 at 12:40pm
 Heres what stage 3 looks like.
but go with stage 4 if you can.
[Compression Fittings]
your going to love your system
                   Love
oops forgot to ad.
The video was taken 15 months after I received system.
I have'nt had to ad fluid yet.
Edited by FR3SHM3AT - 22 May 2012 at 12:41pm
Avatar
  Quote tybalt Quote  Post ReplyReply bullet Posted: 23 May 2012 at 11:12am
Ya didn't have the cash for stage 4 :-/ but thanks for the video dam ur set up looks hella clean! Can't wait for my comp just happy it's coming... No pc gaming for the last 5 months has sucked!
ASUS P8Z77-V DELUXE
8GB DDR3 1600MHz
