Subzero liquid cooling stage 3 questionPost Date: 2012-05-21 |
tybalt
Newbie Joined: 10 May 2012 Online Status: Offline Posts: 43 |
Topic: Subzero liquid cooling stage 3 question Posted: 21 May 2012 at 4:43pm |
I was wondering what fluid ds uses? Do they put any add ins like Swiftech hydrx or Fluidxp? I heard that adding these to your liquid cooling system helps reduce the wear and tear on the system
Intel Core i7 3770K 4.5 GHz
ASUS P8Z77-V DELUXE 8GB DDR3 1600MHz (120GBSSD 1TB hard drive) NVIDIA GeForce GTX 670 2GB (Overclocked EVGA) |
Asangard
Quote Reply Posted: 21 May 2012 at 7:34pm |
Hi tybalt
DS uses Feser One Cooling Fluid. It contains ethylene glycol. Here is a quote from the bottle. "Ready to use anti-corrosion fluid. Protects copper, aluminium, brass and nickel." Then it says: "Do not mix with other liquids". I hope that helps. |
tybalt
Quote Reply Posted: 21 May 2012 at 8:07pm |
Thanks asan! Exactly what I was looking for. Just wanted to make sure it wasn't just water. Thanks again
Alex
Quote Reply Posted: 21 May 2012 at 11:15pm |
Nope, no water.
tybalt
Quote Reply Posted: 22 May 2012 at 12:10am |
One last question about it... Does anyone know the maintenance on it? Do you have to flush it? Will I have to add more fluid later? Thanks again alex and asan
surf71zx
Groupie Joined: 07 Jan 2011 Online Status: Offline Posts: 485 |
Quote Reply Posted: 22 May 2012 at 7:00am |
Its recommended to be done every 3 years. Your fluid levels do drop.Order a bottle of the Feser and they will send it with your computer.
tybalt
Quote Reply Posted: 22 May 2012 at 10:07am |
Good to know! I'll set a reminder when I get my comp. Want this thing to last! Thanks surf
FR3SHM3AT
Groupie Joined: 12 Feb 2011 Online Status: Offline Posts: 494 |
Quote Reply Posted: 22 May 2012 at 12:40pm |
Heres what stage 3 looks like. but go with stage 4 if you can.
[Compression Fittings]
your going to love your system
oops forgot to ad.
The video was taken 15 months after I received system.
I have'nt had to ad fluid yet.
Edited by FR3SHM3AT - 22 May 2012 at 12:41pm |
tybalt
Quote Reply Posted: 23 May 2012 at 11:12am |
Ya didn't have the cash for stage 4 :-/ but thanks for the video dam ur set up looks hella clean! Can't wait for my comp just happy it's coming... No pc gaming for the last 5 months has sucked!
