System monitoring parametersPost Date: 2009-06-02 |
Bahger
Groupie Joined: 06 May 2009 Online Status: Offline Posts: 279 |
Topic: System monitoring parameters Posted: 02 Jun 2009 at 1:19am |
Thanks to a recommendation from these forums I downloaded Everest, a great utility. I run it in a sidebar and can choose which performance specs I want to see there. Can someone tell me which specs are the most important to monitor (CPU/GPU temps, fan speeds, etc.)? Should I set temperatures to show in degrees C or F? Finally can someone tell me what the "red line" numbers are for the key categories? Many thanks. |
<8) slunK parade
Senior Member Joined: 20 Jan 2009 Online Status: Offline Posts: 798 |
Quote Reply Posted: 02 Jun 2009 at 1:51am |
just monitor cpu and gpu
make sure they dont get above 80degrees Celsius |
Clinton
Groupie Joined: 08 Sep 2007 Online Status: Offline Posts: 298 |
Quote Reply Posted: 02 Jun 2009 at 10:20pm |
Your GPU is ok over 80 degrees celsius, but try not letting your CPU get that hot.
