Two Rather Simple Questions
Post Date: 2007-09-17
Bill the Cat View Drop Down
Avatar
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Topic: Two Rather Simple Questions
    Posted: 17 Sep 2007 at 1:00am
1) I always just assumed that the optical drives offer were IDE drives. Is this true?
2) Are the versions of XP and Vista offered OEM or retail?
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 17 Sep 2007 at 3:06am
1) To a certain extent. You can get SATA optical drives. As or right now, our Lightscribe DVD-RW drives are SATA optical drives. The rest are IDE.
2) They are OEM. You will still receive a original Windows installation CD.
commast View Drop Down
Guest
Guest
  Quote commast Quote  Post ReplyReply bullet Posted: 17 Sep 2007 at 3:15am
Oh oh, i was under the impression that ALL the optical drives from DS are SATA drives. Guess i have to get my old PCI IDE adapter to install a spare hard drive i still has Ouch
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 17 Sep 2007 at 3:22am
Sorry! We are trying to phase IDE drives out slowly. Some builds with SATA optical drives have been causing issues with our install kits.
Guest
Guest
  Quote commast Quote  Post ReplyReply bullet Posted: 17 Sep 2007 at 3:30am
Alex, what kind of issues are you having with the SATA drive ?? I may have to install the SATA optical drives on my build soon after it arrive.
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 17 Sep 2007 at 9:58pm
It's mainly with our special network install setup we have. It's not with basic OS  installs.
Guest
Guest
  Quote commast Quote  Post ReplyReply bullet Posted: 18 Sep 2007 at 12:57am
Ok, great. Thanks Alex
Avatar
  Quote Alex Quote  Post ReplyReply bullet Posted: 18 Sep 2007 at 1:51am
You're welcome, when we try to Install Windows from our Network Shares, the system will give a Blue Screen. We believe it has to do with the SATA driver and the network connection. Anyway, this issue does not affect us in any way or manner, we have already developed a fix for it.
