[UPDATED]Need help with the config for game and vrPost Date: 2016-10-25 |
wx0165927473
Newbie Joined: 25 Oct 2016 Online Status: Offline Posts: 1 |
Topic: [UPDATED]Need help with the config for game and vr Posted: 25 Oct 2016 at 7:47pm |
Here is my usage.
Budget: Around $5000 Expectations: doing VR development and playing games Usage: Basically Unreal and 3dMax Here is the config I pick, any suggestions? Chassis Chassis Model: Aventum 3 (ETA Early November) Exterior Finish: Black Metallic Matte Finish Core Components Processor: Intel Core i7 6800K 3.4GHz (6-Core) (Unlocked CPU) Motherboard: ASUS X99 STRIX GAMING (Intel X99 Chipset) (Up to 4x PCI-E Devices) (RGB Lighting) System Memory: 32GB DDR4 2666MHz Corsair Dominator Platinum DHX (Extreme-Performance) Power Supply: 850W EVGA SuperNOVA Storage / Connectivity Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 8x / CD-Writer 8x) (Internal) Storage Set 1: 1x SSD (512GB Samsung 850 PRO) Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics / Multimedia Graphics Card(s): 1x GeForce GTX 1080 8GB (NVIDIA Founders Edition) (VR Ready) Sound Card: Integrated Motherboard Audio Digital Storm Engineering Extreme Cooling: H20: HydroLux PRO: Exotic Custom Cooling System (CPU Only) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Red Fluid (Requires HydroLux Liquid Cooling System) Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair Airflow Performance Edition (Up to 6 Fans) Internal Lighting: Digital Storm RGB LED Lighting System (Requires Thermal Management Control Board & Software) Airflow Control: Digital Storm Thermal Management Control Board & Software Noise Reduction: Noise Suppression Package Stage 1 (Optimized Airflow & Fan Speeds Only) Digital Storm TwisterBoost Technology Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) Software Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Accessories / Goodies Customer Care Priority Build: - No Thanks, Ship Within 15-20 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) https://www.digitalstorm.com/configurator.asp?id=1509902 Edited by wx0165927473 - 26 Oct 2016 at 8:18pm |
Quote Reply Posted: 27 Oct 2016 at 4:24pm |
Looks good but get rid of noise package its pointless.
Bit of info: 1. Do not install Mcafee , instead get a lighter better anti virus like ESET ( number 3 on the list ) Or any other good light Anti Virus will do. 2. With extra fans request that DS changes all case fans and connects all your fans to the mobo so you can control them via free software. This way we can control the fans without needing anything else (aka fan controller and etc). Also be sure to pick the color of the ring you wan the fans to have (red/blu/white). 3. The warranty here is 3 year labor and 1 year parts so if you want higher part warranty be sure to raise the warranty level to the desired level. |
kwx
Newbie Joined: 19 Sep 2016 Online Status: Offline Posts: 14 |
Quote Reply Posted: 31 Oct 2016 at 3:04pm |
Alternatively, here's one based on my build which I just received this Fri. It's slightly cheaper even though it includes a watercooled Titan XP instead of the 1080. It uses a 6700k CPU which is fine for gaming, though more cores may be helpful for development.
FYI, this build has 16G RAM, make sure you adjust that and other components to match your requirements. I didn't check in detail if there's any other big differences. https://www.digitalstorm.com/configurator.asp?id=1513355 Configuration Code: 1513355 Total Price with Instant Savings: $3,813.00 Direct Load URL: https://www.digitalstorm.com/configurator.asp?id=1513355 Specifications: Chassis Model: Special Deal Hot Seller - Corsair Carbide Quiet 600Q Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170 PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices) System Memory: 16GB DDR4 2666MHz Digital Storm Certified Performance Series Power Supply: 750W EVGA SuperNOVA Expansion Bay: Hard Drive Hot Swap Bay (EZ-Rack) Optical Drive: - No Thanks Storage Set 1: 1x SSD M.2 (512GB Samsung 950 PRO) (NVM Express) (Extreme Performance) Storage Set 2: - No Thanks Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX TITAN X 12GB (Pascal) (NVIDIA Founders Edition) (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: HydroLux LITE: Integrated Cooling System (1x Graphics Card + CPU) HydroLux Tubing Style: Flexible Tubing (Requires HydroLux Liquid Cooling System) HydroLux Fluid Color: Clear Fluid (Requires HydroLux Liquid Cooling System) Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: Digital Storm Thermal Management Control Board & Software <br><strong></strong> Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Standard Intel Turbo Boost 2.0 Automatic Overclocking <br><strong></strong> Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) <br><strong></strong> Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows CD) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
