Using 50+ % Physical MemoryPost Date: 2008-11-06 |
jtspectra2
Senior Member Joined: 07 Oct 2008 Online Status: Offline Posts: 840 |
Topic: Using 50+ % Physical Memory Posted: 06 Nov 2008 at 5:26pm |
When i look in my tast manager it shows CPU usage and Physical Memory. M y Cpu Usage is fine, i cant get that thing to go up past 30 no matter what i do. as for my physical memory. its at 56 % right now and all im doing is typing this to you and listening to some music. is this normal???
Quote Reply Posted: 06 Nov 2008 at 5:46pm |
you are on vista and that is vista's superfetch.
we can disable that if you like, I have mine disabled. |
jtspectra2
Quote Reply Posted: 06 Nov 2008 at 5:50pm |
hmm iv never heard of that . how much of a difference is it gunna make in my performace. go ahead and tell me how to do that
Quote Reply Posted: 06 Nov 2008 at 5:58pm |
not much unless you demand lot of ram real quick, I just like to load resources as I go, instead of ahead of time.
Always backup registry before making any edits 1. Click the Start orb and type REGEDIT in the Start Search area. 2. Open the Registry Editor. 3. Click the plus sign next to HKEY_LOCAL_MACHINE then SYSTEM then CurrentControlSet then Control then Session Manager then MemoryManagement then click PrefetchParameters 4. On the right side, double-click on EnableSuperfetch 5. Give it one of the following values: 0 to disable Superfetch (I set mine to this) 1 to enable prefetching when program is launched 2 to enable boot prefetching 3 to enable prefectching of everything Click OK. 6. Close the Registry Editor. 7. Reboot pc. Edited by DST4ME - 06 Nov 2008 at 8:22pm |
