Uv reactive Die or clear fluid
Post Date: 2012-06-12
tju76 View Drop Down
  Quote tju76 Quote  Post ReplyReply bullet Topic: Uv reactive Die or clear fluid
    Posted: 12 Jun 2012 at 8:29pm
any disadvantages from adding some uv reactive dye into my cooling loop, i saw a post that said it can ruin the components, junk up the pumps? thanks guys
Err0xx View Drop Down
  Quote Err0xx Quote  Post ReplyReply bullet Posted: 12 Jun 2012 at 8:36pm
I imagine it depends on the properties of the UV dye. Most is labeled as non-corrosive, etc. I've had UV reactive dye in a cooling loop on my current pc for 6 years. Never had a single issue with it, still running good.
  Quote tju76 Quote  Post ReplyReply bullet Posted: 13 Jun 2012 at 11:42am
could you reccomend me a brand? what do you use?
  Quote Asangard Quote  Post ReplyReply bullet Posted: 13 Jun 2012 at 7:05pm
Hi tju76,
I beleive DS still uses Feser One Cooling Fluid (clear) which is UV reactive.  So you shouldn't need to add any thing to your cooling loop.
  Quote tju76 Quote  Post ReplyReply bullet Posted: 13 Jun 2012 at 8:03pm
no its clear liquid trust me lol, And the stage 6 LC are all the parts copper like rads blocks
  Quote Alex Quote  Post ReplyReply bullet Posted: 13 Jun 2012 at 9:38pm
We use Feser One clear, which can be UV reactive with cold cathode UV lights (however it won't be super bright like UV green fluid).
  Quote Asangard Quote  Post ReplyReply bullet Posted: 14 Jun 2012 at 3:55am
The Feser One Clear used by DS is UV reactive.  You need a UV light source to make it glow.  If you are looking for a colored fluid that is also UV reactive Feser makes a number of different colored fluids that are also UV reactive.  Here is a link to their site: http://www.tfc-us.com/shop/
You will still need a UV light source to lake them glow.
I hope this helps.
Edited by Asangard - 14 Jun 2012 at 3:56am
  Quote tju76 Quote  Post ReplyReply bullet Posted: 14 Jun 2012 at 4:55am
Since the liquid is not just distilled water how often should I take everything out of the loop to clean it like the rads and blocks
surf71zx View Drop Down
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 14 Jun 2012 at 8:11am
tju76 on the Feser One cooling fluid bottle it says in BOLD HIGH LIGHTED letters, Do Not Mix with other liquids. Take it for what its worth from the manfacturer. There address is www.Feser-One.com.
  Quote tju76 Quote  Post ReplyReply bullet Posted: 14 Jun 2012 at 11:00am
yeah i am not mixing anything into the fesser i thought it was just clear liquid not uv reactive i am buying some more UV CCFL lights todays, how often should i clean all of the components in the loop
  Quote Err0xx Quote  Post ReplyReply bullet Posted: 14 Jun 2012 at 6:08pm
To my knowledge, not very often. The Feser is non-corrosive so you wouldn't benefit much from it. I've had 3 liquid cooled pc's in the the past and haven't cleaned the liquid cooling loops but about once every 3ish years if using non-corrosive liquid. I'd say just watch your temps and consider cleaning them if they start getting higher than normal.
Not sure how to best instruct you as to cleaning them, it's not really something I've done- the liquid cooling loops I've had experience with in the past are very low maintenance, I don't suspect these are really any different.
  Quote tju76 Quote  Post ReplyReply bullet Posted: 14 Jun 2012 at 6:44pm
thank you for your answer
