V4L4 CPU TempsPost Date: 2016-02-09 |
Htoler
Groupie Joined: 07 Feb 2009 Online Status: Offline Posts: 241 |
Topic: V4L4 CPU Temps Posted: 09 Feb 2016 at 10:20pm |
During gaming CPU temps are hitting mid 50`s is this safe or should I consider upgrading CPU cooling ?
Edited by Htoler - 09 Feb 2016 at 10:20pm |
Htoler
Quote Reply Posted: 09 Feb 2016 at 10:53pm |
have decided to just go ahead and install
Corsair Hydro Series™ H80i V2 Water / Liquid CPU Cooler if nothing ealse it will look sharp looking into the case at the lighted logo on the CPU cooling block |
Snaike
Moderator Group Just a dude trying to keep the spam away Joined: 23 Jan 2014 Online Status: Offline Posts: 9459 |
Quote Reply Posted: 10 Feb 2016 at 12:48am |
50s are not a concern. 70s are not a concern.
mid 80s are where the problems lie. But, if you want a cooler, help yourself... they look really sharp. |
Alex
Quote Reply Posted: 10 Feb 2016 at 9:46am |
Your temps are perfectly fine, upgrading the cooling system further is not really going to help you in performance or stability. However, in terms of aesthetics, it surely will.
Htoler
Quote Reply Posted: 10 Feb 2016 at 12:21pm |
yea it will looking into the case seeing that light up Corsair Logo will look cool will post pics of it when I get it and get it installed .
Htoler
Quote Reply Posted: 10 Feb 2016 at 10:23pm |
has anyone used these on their Push fans on Cooling radiator to cut down on the dust clogging fins under fan ?http://www.newegg.com/Product/Product.aspx?Item=9SIA6J32GM5522&cm_re=120mm_fan_cover-_-9SIA6J32GM5522-_-Product
Htoler
Quote Reply Posted: 11 Feb 2016 at 1:20am |
Htoler
Quote Reply Posted: 11 Feb 2016 at 1:31am |
