Vanquish 5 problemsPost Date: 2017-01-05 |
zminnis4
Newbie Joined: 05 Jan 2017 Online Status: Offline Posts: 3 |
Topic: Vanquish 5 problems Posted: 05 Jan 2017 at 2:23pm |
I bought a Vanquish 5 a few months ago. It has ran perfect up until today. I turned it on, proceeded to play 3 games of h1 KOTK. Then my PC suddenly shut off while i was playing. Now the tower wont turn on at all. I've done the basics, flipping power switch on back, plugging unplugging cord, plugging straight into wall outlet. What should I do?
ZM
Quote Reply Posted: 05 Jan 2017 at 2:35pm |
Sorry to hear, and I hate to say, but it sounds like your power supply died.
Just the obvious....there is power at the wall outlet and not a breaker tripped ? I would open the side panel and check all the wires going to the motherboard. There is the 24 pin, 6/8 pin above CPU and the small wires going to bottom corner of motherboard that come from front panel power on switch. Remove the video card and try it. |
zminnis4
Quote Reply Posted: 05 Jan 2017 at 9:31pm |
Thats what I assumed it was. Yes theres power to the outlet and the wires seem to be fine and connected
ZM
capman
Newbie Joined: 31 Dec 2016 Online Status: Offline Posts: 4 |
Quote Reply Posted: 06 Jan 2017 at 10:53am |
One simple trick to try... Some call it draining flea power. Basically, unplug the machine and hold the desktop power button down for 30 seconds. This will completely drain power from any capacitors on the system board. Then plug it back in, make sure the power supply switch is on and try again. May be a true hardware issue, but it is a quick and simple process to try this.
zminnis4
Quote Reply Posted: 06 Jan 2017 at 2:14pm |
Yeah i tried that the other day. Appreciate the comment though. They are sending me a new PSU |
ZM
Quote Reply Posted: 06 Jan 2017 at 2:27pm |
Good to hear the fix is in the mail.
Not sure your psu is semi modular, but if so, you might get away with just pulling out the 24 pin and 6 pin from mobo, and the others just unplug from the supply. Makes life easier. |
