Vanquish 7 level 1 lag spikesPost Date: 2018-07-14 |
Knelliare
Newbie Joined: 14 Jul 2018 Online Status: Offline Posts: 7 |
Topic: Vanquish 7 level 1 lag spikes Posted: 14 Jul 2018 at 4:07pm |
Hello everyone maybe i can get some help here. I bought a Vanquish 7 Level 1 back in may and it arrived the end of June so another week i will have had for a month or so. i havent really made any changes to any settings or anything my question is why would i be getting lag spikes on all of my games most of which are at least 3-5 years old. When i am not spiking i am getting between 30 and 60 fps easy. Any help on this would be appreciated
Snaike
Moderator Group Just a dude trying to keep the spam away Joined: 23 Jan 2014 Online Status: Offline Posts: 9448 |
Quote Reply Posted: 14 Jul 2018 at 10:57pm |
Im not one of the smarter folks here about our machines, but I do recall lag spikes being a function of the ISP or Router and not the machine.
When you start to see spikes, online, run over to Fast.com and get a speedcheck. Then compare that with what you're paying for. I've gone round and round with ATT and finally convinced them there was a problem when I could show them weeks worth of data that I'd saved. But then again, that was my issue, I don't know what your's is, but it is worth a look. Cheers |
Knelliare
Quote Reply Posted: 14 Jul 2018 at 11:29pm |
could be part of my issue for the online stuff but games like witcher 3 and mass effect trilogy that are single player not so much i dont think
Knelliare
Quote Reply Posted: 14 Jul 2018 at 11:35pm |
on second thought internet speed is not an issue for me i checked i can run SWTOR on high settings at 12 ms latency and when the lag spikes happen my latency doesnt spike so probably not the cause
Quote Reply Posted: 15 Jul 2018 at 2:02am |
My guess is that the lags are a function of the relatively weak integrated VEGA 11. graphics processor in the level 1. The level 1 doesn’t have a separate graphics card. That graphics chip , part of the cpu, is a good entry level processor for gaming with less demanding games. You can certainly game with it, but not on a 1080p monitor on higher settings with certain games.
The Witcher 3 for example is an older game but still very demanding. My older gtx 970 , which is many times stronger than the Vega 11, would lag a lot if I had it on higher settings. Same for Mordor. I would Google the Vega 11 benchmarks for the games you play to see what to expect. The other suggestion is to go into Task Manager and see if anything is running in the background that’s chewing up your cpu resources. Edited by bprat22 - 15 Jul 2018 at 2:03am |
Snaike
Quote Reply Posted: 15 Jul 2018 at 8:28am |
So it's not so much a lag spike as it is an FPS drop?
Knelliare
Quote Reply Posted: 15 Jul 2018 at 8:56am |
Ya they go from 30-60 fps down to 1 I would say that that could be the cause but I checked the spikes still happen even if I have the game on low settings with AA and everything turned off
Quote Reply Posted: 15 Jul 2018 at 9:54am |
A possible fix is to go to AMD website and download and update the Vega 11 graphics driver. Being integrated I'm not familiar with the exact process, but should be just a download and install.. Windows might just be seeing the integrated graphics as a basic driver and not using its potential. Let us know if it works.
Knelliare
Quote Reply Posted: 15 Jul 2018 at 11:07am |
Thanks guys I will look into that when I get a chance
Knelliare
Quote Reply Posted: 15 Jul 2018 at 3:46pm |
sorry to say the driver dl from amd didnt fix it i am thinking u guys may be right think it might be my monitor i am currently running an Asus VS238 and generic Dell monitor as my dual setup
nubatpc
Newbie Joined: 09 Jun 2018 Online Status: Offline Posts: 31 |
Quote Reply Posted: 16 Jul 2018 at 2:40am |
you can give more Ram just for ur CPU CZ the level 1 runs of integrated graphics which use the system Ram.it helped with my laptop
suck at pc
hoserator
Quote Reply Posted: 16 Jul 2018 at 4:38am |
Try only one monitor.
Knelliare
Quote Reply Posted: 19 Jul 2018 at 1:52pm |
thanks for all the suggestions folks running only 1 monitor now its less of a lag spike now and it doesnt happen as often so doesnt affect my gaming as much as it did before looks like i will just have upgrade it a bit to be able to run dual in the future
hoserator
Quote Reply Posted: 20 Jul 2018 at 2:40am |
I have read that that chip likes a lot of fast RAM. Something to consider depending on the RAM you got. Easy to change and might be cheaper than adding a dedicated gpu. Good luck and happy gaming.
