Vanquish II Side PanelPost Date: 2014-12-27 |
BlueHoundZulu
Newbie Joined: 27 Dec 2014 Online Status: Offline Posts: 1 |
Topic: Vanquish II Side Panel Posted: 27 Dec 2014 at 5:42pm |
So after I cleaned out my Vanquish in the morning and went to put the side panel back one I noticed something weird, it didn't line up. First I had issues where the whole thing was about .5cm off from the back. Now I have it to the point or the middle point(where the thumbscrew is) is flush with the back, but the top and middle are still .5cm out from the edge. I was wondering if any other user has had this problem or if its just an issue w/ me putting it on like a moron.
Drift Spaceman
Newbie Joined: 02 Dec 2014 Online Status: Offline Posts: 19 |
Quote Reply Posted: 29 Dec 2014 at 8:34am |
When I first opened mine up after getting it shipped to check if everything was in the right place and take out the foam packing material, it took me about 5 minutes and multiple tries to get it back on where it needed to be. It didn't just slip right into place. You're not alone, lol. |
FrankW
Quote Reply Posted: 29 Dec 2014 at 2:39pm |
I have a HAF 922 case and the side panel has never fit perfectly.
Frank |
