Vanquish lvl 4 systemPost Date: 2013-08-04 |
kosmos6
Newbie Joined: 04 Aug 2013 Online Status: Offline Posts: 21 |
Topic: Vanquish lvl 4 system Posted: 04 Aug 2013 at 6:50pm |
So I am thinking about investing in the Vanquish lvl 4. I was just
curious as to if this computer could run a Game with an older graphics
engine like Dark Age of Camelot at maximum graphic setting with no
issues.
Also would it Run Guild Wars 2 without having any issues with graphics at max settings? Looking for the best bang for my buck limited price range. If i could get away with a lower level system and still be able to maximize my graphics on both of these games please let me know! =] Thanks for any input you could help me with! |
fstcvc
DS Veteran Joined: 06 Jul 2013 Online Status: Offline Posts: 2551 |
Quote Reply Posted: 04 Aug 2013 at 9:41pm |
Welcome to DS! I'm sure if once you get your new system, you'll be glad you stopped by!
Looking at the system requirements of those 2 games, a VANQUISH Level 4 should have no problem handling them. I also think you could get away with the Level 3 system. Depends on what you plan on playing in the future. The Level 4 will definitely handle newer & future games better. Always buy the best you can afford (set a budget!) so that way you don't have to re-upgrade as soon... |
i7 4770K @ 4.5GHz Asus Maximus VI Extreme 16GB Corsair Dominator Platinum 3xSLI EVGA SuperClocked GTX TITAN Samsung 840Pro SSD 256GB+512GB HydroLux+XSPC CPU/MoBo/GPU Liquid Cooling |
Ariktu
Groupie Joined: 21 May 2013 Online Status: Offline Posts: 492 |
Quote Reply Posted: 05 Aug 2013 at 10:50pm |
I would think you would have no issues. My level 4 came with a GTX 670 and runs games great. I believe the current one uses a GTX 680 which is better than my GPU.
You can also look into the special edition one with the GTX 770 for 1449. Here is the link to it if you want to compare them. http://www.digitalstormonline.com/comploadvanquish.asp?id=834157 Edited by Ariktu - 05 Aug 2013 at 10:50pm |
Sernafied
Groupie Joined: 16 May 2013 Online Status: Offline Posts: 116 |
Quote Reply Posted: 12 Aug 2013 at 11:29pm |
I play GW2 with everything maxed. Large group engagements rock me down to <30fps, but if it's just me and a few others I'm between 80 and 130ish. Stats are in the sig
Edited by Sernafied - 12 Aug 2013 at 11:29pm |
i7 3770k @ 4.4
16GB 1600MHz Corsair Dominator 240GB Corsair Neutron SSD 1TB Storage GTX 690 |
