Vanquish problemPost Date: 2018-01-16 |
Savla
Newbie Joined: 16 Jan 2018 Online Status: Offline Posts: 4 |
Topic: Vanquish problem Posted: 16 Jan 2018 at 9:26pm |
Hi, I just set up my vanquish and when I turned it on it booted up to the BIOS. I'm pretty tech illiterate, so is this normal? and how do I exit out of the BIOS without breaking anything. Sorry if this is completely obvious lol
Cretae
DS Veteran Joined: 22 Mar 2010 Online Status: Offline Posts: 7330 |
Quote Reply Posted: 17 Jan 2018 at 12:16am |
As long as you weren't mousing around or typing furiously while in your bios lol, I'd just hit your reset if you see it, or power down and power back up again after a half minute or so. If you boot into Windows, you're good. If you get stuck in the bios again, you'll want to power down and wait a couple of minutes. Then remove the side of the case where you can see all the parts, make sure you touch some metal on the edge of the case to ground yourself, and gently start to go from part to part looking for anything not fully seated. Especially your main hard drive. Hope that gets you going.
Quote Reply Posted: 17 Jan 2018 at 1:28am |
F10
the y for yes save or n for no don't save Choose one and it will reboot |
Quote Reply Posted: 17 Jan 2018 at 2:25am |
Yep, if the SSD main drive with OS on it got unplugged during shipping, the pc will boot to Bios. Check the 2 connectors to the drive.
Or it’s just as DST said. Edited by bprat22 - 17 Jan 2018 at 2:26am |
Savla
Quote Reply Posted: 17 Jan 2018 at 3:06am |
I assume you meant these two cables, I unplugged them and and plugged them back in, but now my system wont even turn on :( :( |
Quote Reply Posted: 17 Jan 2018 at 3:16am |
What do you mean by it won't turn on?
Savla
Quote Reply Posted: 17 Jan 2018 at 3:26am |
I try to start it up, by pressing the power button, but it wont do so now. checked the power cord, dont know why it's happening, think I'm just going go wait until tomorrow and call digital storm before something even worse happens... |
Quote Reply Posted: 17 Jan 2018 at 3:34am |
Those are not the wires he was talking about, did you connect and disconnect them when pc was connected to the wall?
When you say it won't i assume you mean no power if so: Give your psu 20 minutes then try again Edited by DST4ME - 17 Jan 2018 at 3:34am |
Savla
Quote Reply Posted: 17 Jan 2018 at 3:44am |
I believe I did sadly, though I did flip the power switch off before doing so, but that may not matter. Alright, I'll do that, thank you man. |
Quote Reply Posted: 17 Jan 2018 at 3:57am |
Yeah, those aren’t the plugs to SSD. I can’t tell what plugs they are. If the cable go to the front of the case it could be the power on switch isn’t connected properly. The front panel with usb, power on, etc go to the motherboard to plug in.
Unplug the pc and reseat those plugs making sure the pins line up. Check the other connectors while you’re in there. |
Quote Reply Posted: 17 Jan 2018 at 4:13am |
Always unplug from the wall and wait till you see no lights/leds on at all then begin work.
Wait the 20 minutes and see if it powers on if not then unplug and do what bp said above. One of those looks like a fan can't make out what the other is Edited by DST4ME - 17 Jan 2018 at 4:14am |
Leal47
Newbie Joined: 19 Dec 2017 Online Status: Offline Posts: 25 |
Quote Reply Posted: 17 Jan 2018 at 9:19am |
This makes me uneasy... Mine arrives tomorrow!
Quote Reply Posted: 17 Jan 2018 at 9:40am |
The vast majority of systems from DS arrive with no issues at all. However, sometimes the jolts the box takes during shipping will loosen a plug, etc. or plugging into a different AC supply from what DS uses can effect overclock. Any problems, post here if DS isn't open or is very busy and we'll see if we can help. |
Quote Reply Posted: 17 Jan 2018 at 8:30pm |
This has nothing to do with your system, he worked in his pc with it in the wall. Also things go wrong at anytime which is why we are here, because DS takes good care of us including the op |
