vista and xp on the same machine?
Post Date: 2007-08-25
Sikboy1029 View Drop Down
  Quote Sikboy1029 Quote  Post ReplyReply bullet Topic: vista and xp on the same machine?
    Posted: 25 Aug 2007 at 11:11pm
Just curious if each OS gets their on partition, or is it done differently? I'll probably be ordering a DS system in 6 or 7 weeks and was wondering how that worked
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 25 Aug 2007 at 11:17pm
Each OS should have their own partition or you going to encounter problems down the road.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 25 Aug 2007 at 11:26pm
As I thought, DS will set it up if I request it, right?
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Posted: 25 Aug 2007 at 11:40pm
Yes we would.  But understand, there is a small chance that something would work great in one os, but not the other.  we can't be responsible for that.
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 25 Aug 2007 at 11:40pm
Yep.
We are obsessed with ensuring our customers receive the very best computer experience.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 25 Aug 2007 at 11:47pm
I understand something might work well in one OS and not the other, I'm thinking of getting a 500GB hard drive and using 150GB for XP and the rest for Vista
  Quote Kelly Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 12:46am
is this a gaming system?
Kenny View Drop Down
Digital Storm Engineering
  Quote Kenny Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 4:24am
Yes, you can use both XP and Vista in the same 1 Hard Drive, and there are no any problems, also they will work fine too.
Because I'm using Windows XP Professional SP2 and Vista Ultimate 32-bit in 1 Hard Drive.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 11:14am
Yes, it will be a gaming system
  Quote Kelly Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 11:35am
then spend the extra cash, get yourself a 150 raptor, dual boot it with each os, (cut the raptor in half for each os partition), then get a 500GB+ for games.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 11:40am
How would that work?
  Quote Kelly Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 12:42pm
well 2 hard drives.  1 for the OS installations and 1 for games and all your other programs.
it's an easy setup.  I have 8 hdds.  :P
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 12:49pm
well I think the 74GB would be big enough for 2 OS installations. Just out of curiosity, why recommend a raptor hard drive to install the OS on?
  Quote Kelly Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 1:08pm
because, the pagefile being on the fastest drive is where your performance will be.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 1:29pm
I see, so if I do decide to go with the dual drive dual boot setup I would have to install different drivers for each OS, right?
Dave View Drop Down
  Quote Dave Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 1:55pm
Originally posted by skyR
Yep.
so true even when you call them the phone message says it o.O
X-Fire: OddityX1337
Yahoo: l33tz0rz1337
Rick Rolled Son!
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 26 Aug 2007 at 2:06pm
sounds like it could be a pain, on a completely unrelated note, would it be possible to get both a floppy drive and  media card reader in my pc?
  Quote Alex Quote  Post ReplyReply bullet Posted: 27 Aug 2007 at 3:07am
We can do it, as a special request. We don't offer it as a option because of compatibility problems.
Let us know your exactly configuration, and we will see if we can fit both a floppy drive and card reader.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 27 Aug 2007 at 12:34pm
here's the config I'm looking at, think you could do it for this one?
http://digitalstormonline.com/comploadsaved.asp?id=75906
  Quote Alex Quote  Post ReplyReply bullet Posted: 28 Aug 2007 at 2:18am
Yes we can. Please ask for the special option when placing an order.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 28 Aug 2007 at 2:05pm
Good to hear, haven't even ordered a system yet and I'm already enjoying the customer service Smile
  Quote Alex Quote  Post ReplyReply bullet Posted: 29 Aug 2007 at 12:20am
Get use to it, that's how we are.
Nendain View Drop Down
  Quote Nendain Quote  Post ReplyReply bullet Posted: 29 Aug 2007 at 3:13am
I went a little different route in setting up my dual boot XP/Vista
Windows XP installed on it's own 150gb raptor HDD 1.
Windows Vista installed on it's own 150gb raptor HDD 2.
Data drive for apps/games of both OS on 500GB x2 in raid 0 HDD 3 & 4.
I do not like my page file on my system(OS) drive.
HDD 5
36gb raptor drive partitioned into two partitions of equal size 18/18.
Setup a page file for XP on the first partition and set min and max size to 12gb 3 times the amount of ram installed.
Setup a page file for Vista on the second partition and set min and max size to 12gb 3 times the amount of ram installed.
Edited by Nendain - 29 Aug 2007 at 3:06pm
  Quote Kelly Quote  Post ReplyReply bullet Posted: 29 Aug 2007 at 9:50am
I have mine:
150 Raptor partitioned - 1/2 for XP Pro, and 1/2 for Vista Ult.
300 Raptor (2x150 raid 0) for games
1 TB (2x500) for storage and apps.
I may get a 32Gig Raptor for my pagefile only.  Not sure yet.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 29 Aug 2007 at 12:01pm
that sounds like it could get expensive, I'm looking to spend around $2200 or $2300
commast View Drop Down
Guest
Guest
  Quote commast Quote  Post ReplyReply bullet Posted: 30 Aug 2007 at 11:32pm
You still can have a great system around that price. You probably have another hard drive lying around at your place which you can install later and use that as a swap file drive or to store all your stuffs. For around $2200-$2300 you can still get 2 HD or a great big one and still have enough money to build a real nice machine.
  Quote Sikboy1029 Quote  Post ReplyReply bullet Posted: 31 Aug 2007 at 9:09pm
do have an extra hard drive but it's junk, can't even run quake 3 engine games on it and it's only 10GB Ouch
