Voltage HelpPost Date: 2008-12-31 |
JVCJr79
Newbie Joined: 12 Oct 2008 Online Status: Offline Posts: 47 |
Topic: Voltage Help Posted: 31 Dec 2008 at 3:40pm |
Hi All
I was having blue screen problems while using my new comp. I thought it may have been due to the overclock so I reset bios to factory settings. Needless to say I think I screwed some items up. Can someone please take a look at these voltages and see if they seem ok? What is the VIN2 voltage and why is it so low? |
JVCJr79
Quote Reply Posted: 31 Dec 2008 at 3:41pm |
Here is another pic
XpubuX
Senior Member Joined: 16 Oct 2008 Online Status: Offline Posts: 726 |
Quote Reply Posted: 31 Dec 2008 at 3:56pm |
Your computer is not overclocked it is running at 2.83. Speed step is enabled which is why you4r multiplyer is 6 instead of 8.5. Call up Ds and they will help tou with the overclock and raising your voltage. Your vcore says 1.2 but thats after vdrop so its probably set in bios around 1.26. Thats a little low and could be pushed higher. I would call ds so you are coverd by warranty. When I got my pc from ds it wasn't overclocked like it was supposed to be but a quick call on the phone and I had it up and running at 3.4. Dont know about vin2. But whatever. Blue screen is probably from undervoltage is my guess. Join the ds irc chat and I can help you more I got the same chip.
Edited by XpubuX - 31 Dec 2008 at 3:59pm |
