water cooling system for Vanquish II L3?
Post Date: 2014-12-31
seelingk View Drop Down
  Quote seelingk Quote  Post ReplyReply bullet Topic: water cooling system for Vanquish II L3?
    Posted: 31 Dec 2014 at 2:31pm
I recently bought a Vanquish ii level 3 desktop. Anyone know if I can hook up a water cooling system to it?
Many thanks.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 11 Jan 2015 at 9:49am
Hi seelingk,
No one has helped you out with your question so I will give it a go.
The Vanquish II uses the Corsair 230 case. I am not sure what level of water cooling you are asking about but Corsair says that a H80i liquid cooler will work. This is a self contained cooler that requires no maintenance. It only cools the CPU and the GPUs will still be air cooled. There is not a lot of room in your case and not a good choise for full liquid cooling. Not saying it is not possible but you have to install a reservoir, a pump and a radiator in there someplace. Since Corsair rates this case for just a H80i I suspect the radiator is size restricted.
  Quote seelingk Quote  Post ReplyReply bullet Posted: 11 Jan 2015 at 3:06pm
Thanks Frank.
  Quote FrankW Quote  Post ReplyReply bullet Posted: 11 Jan 2015 at 3:19pm
Glad to help.
