What water cooler is in my pc?Post Date: 2015-07-14 |
joshled
Newbie Joined: 13 Jul 2015 Online Status: Offline Posts: 5 |
Topic: What water cooler is in my pc? Posted: 14 Jul 2015 at 5:35pm |
The water cooler in my pc is all black and has no logo on it. just curios as to what brand/model it is
ArkansasWoman777
Quote Reply Posted: 14 Jul 2015 at 7:02pm |
Got a picture of your machine? Its most likely one of the Corsair coolers as that is what is listed in their configurations aside from the Swiftech one in the Bolt config and their custom loops
Quote Reply Posted: 14 Jul 2015 at 7:04pm |
Does it look like one of these?
joshled
Quote Reply Posted: 15 Jul 2015 at 2:50am |
/Users/Ledbetter/.Trash/20150709_141201.jpg Don't know if you guys can view the pic or not this website won't let me share dropbox links
Quote Reply Posted: 15 Jul 2015 at 2:55am |
What sytem did you buy? Vanquish level 3 or 4? Apollo level 1?
Does it have tubes going to a radiator mounted to the inside back wall? Edited by bprat22 - 15 Jul 2015 at 2:56am |
joshled
Quote Reply Posted: 15 Jul 2015 at 3:05am |
I bought the Velox level 2 and the radiator is on top with 2 140mm fans
Quote Reply Posted: 15 Jul 2015 at 3:18am |
A 280mm rad mounted to the top of the Velox is probably their custom Hydrolux water cooling. They use various manufacturers for the components so I couldn't say for sure. The manufacturer is usually stamped on the side, like Swiftech.
A call or email to DS would be the way to go. |
joshled
Quote Reply Posted: 15 Jul 2015 at 3:26am |
ok bprat22 thanks very much ill give them a call
Quote Reply Posted: 15 Jul 2015 at 3:29am |
Let us know what you find out?
Quote Reply Posted: 15 Jul 2015 at 8:06am |
Oh, I forgot that DS changes out the Swiftech logo on the waterblock for their own.
This is what the Swiftech unit looks like on the Bolt 3: |
joshled
Quote Reply Posted: 15 Jul 2015 at 1:55pm |
Found out it is a liquid cooler from a company called Antec probably a older model because i can't find mine on there website thanks for y'alls help btw this cooler doesn't need maintenance right?
Quote Reply Posted: 15 Jul 2015 at 3:17pm |
Can't be sure without seeing it, but Antec is sealed units from what I've seen meaning no maintenance. If the black hoses go from the cpu block directly to the radiator, no reservoir or pump, then its no maintenance.
