Work Station for motion graphics
Post Date: 2016-08-11
Android16 View Drop Down
  Quote Android16 Quote  Post ReplyReply bullet Topic: Work Station for motion graphics
    Posted: 11 Aug 2016 at 4:08pm
Around $8000
Rendering 2D and 3D graphics using after effects, Cinema 4D, and Octane
Saved Ticket #: 1465486
I want this except with three graphics cards instead of 4
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Aug 2016 at 8:29pm
Ok lets see, first let me ask you, would you not be better off in a workstation?
and why 980ti and titan pascal?
Drop the noise reduction, with 3 gpus on air youy gonna want better airflow, I would got with the velox case instead.
drop the os boost, there is no boost. If you are noticing any kind of boost whatsoever from doing anything with the os then something is wrong. with 8 cores, 32GB of ram, there should be nothing I could with the os that you would notice performance difference. BTW is 32GB enough for your work?
soulmanim3 View Drop Down
  Quote soulmanim3 Quote  Post ReplyReply bullet Posted: 12 Aug 2016 at 6:19am
Agreed - Rendering will chew through all the RAM you can throw at it if you let it.
Ordered - 07/02/2016 | Stage 7 - 08/15/2016
Stage 1 - 07/05/2016 | Shipped - 08/16/2016
Stage 2 - 07/11/2016
Stage 3 - 07/11/2016
Stage 4 - 07/26/2016
Stage 5 - 07/26/2016
Stage 6 - 08/04/2016
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 12 Aug 2016 at 2:36pm
i don't think you can do 4xsli and m.2 nvme storage at the same time.  if it's possible very few boards out there that can do it.  perhaps the asrock extreme 11?
i agree with DST4ME, a dual Xeon workstation w/a Quadro m5000 would probably be better for your needs.  you should be able to configure one for your budget.
Edited by db188 - 12 Aug 2016 at 3:20pm
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 12 Aug 2016 at 3:54pm
@db just to clarify, he can't choose 3 gpus so he picked 4 but he is going with 3 gpus, based on what he said in his post, otherwise you are 100% correct no quad sli and m.2 on these boards.
