Build help pleasePost Date: 2011-01-16 |
CStormO
Newbie Joined: 21 May 2010 Online Status: Offline Posts: 86 |
Topic: Build help please Posted: 16 Jan 2011 at 3:11pm |
i want to find out how much it will cost to make a top of the line gaming rig without spending unnecessary money ik the basics but not everything i dont really have a budget but i dont want to go crazy unless its worth it resolution id be playing at would be 1920 x 1080 unless higher will give me a better picture read display before answering the resoution question also i will be overclocking this thing to the max i can for 24/7 usage i wont be leaving it on 24/7 but i do game for LONG periods of time 16+ hours sometimes i will order from DS anything they dont have that would be great for the build i want i will order and send to them as ive heard you can do i just did a build with what they already have and it was 5000 didnt think that was bad was expecting higher this is pure gaming build anything else i plan to do idc about performance as much like video editing ik it wont be as good as it could be with more memory and stuff but not worried about that plan to play black ops diablo 3 and starcraft a lot but i will play most big name games as well on it because i prefer PC Case: what case has the best cooling air not liquid dont want to deal with the maintenance that will fit the best amount of video cards Paint Job/Modding: is there a website or anything that you can send them the stuff and they will paint you case or maybe more like keyboard and mouse to match or mod the case(if theres anything good to do) i had a post like this before but never ended up doing it decided to wait but will be doing it now and i know that DS for the most part is gonna have everything i need but if there is anything that will make it better and worth it ill definately do it Edited by CStormO - 16 Jan 2011 at 3:12pm |
Quote Reply Posted: 16 Jan 2011 at 4:48pm |
Before we can build a system for you, we need to know what is the size of the resolution of the monitor you will be playing on.
so lets get that out of the way first. yes a higher res monitor will look better and have more details, a 30" monitor will have a res of 2560 x 1600, building a pc that can handle games at 2560 x 1600 is different then a system that is meant to handle 1900 x 1200. So we need to know this first, what monitor would I recommend for a 30"? and ISP panel since it has the best picture, Dell UltraSharp U3011 30 once you have decided what size monitor you want to go with then we can look at building a system. Now what is your budget for this system? looking at what you might need for a 30" it would be something like this: Here you go Ticket# 478915 --- $3966 (To see this build click here) Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS Maximus IV Extreme (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 3x SLI Triple (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: AIR: Stage 1: Noctua NH-U12P SE Dual 120mm Fans High Performance Cooler H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Home Premium (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty Case has the best airflow, fans are not loud. you have some bad/old info about memory. gpu best band for the buck is the 570, 580 is not worth it. SSD is not about just speed, but when you compare you have to compare 4K file size speed, some ssds say they are faster but when you get to the 4k file speeds, they are not, and that is the speed that matters the most. Intel has the best reliability and wear and tear. HDD setup is suppose to be like this: HDD1 = fast small drive: os/apps/games HDD2 = regular large drive: media/personal/work file storage Go for whatever sound card you like, I'm not a big expert with sound, just make sure its drivers work well with win7 64bit. Killer Cards = waste of money, whatever little difference they make you wont even notice it. Optical Drives, add or change them as you please, this is more about what you need. Chassis Mod, what kind of mod? had needs none, its got the side window, big fans, etc. Noise Reduction = pointless and trap noise, trap heat, no matter what you will endup traping heat, even if the noise reduction kit tells you otherwise, at the end airflow will be restricted, there is just no way around it. OS, Unless you are ready to have lot of headache and drives that don't work, I would not go anything other then windows right now. Display, I covered this at the beginning of the post. Paint Job, DS can do this for you. |
CStormO
Quote Reply Posted: 16 Jan 2011 at 9:27pm |
ok so higher res actually does give a better picture quality after 1920 x 1080? now yes thats probably 1 of the best monitors out if not the best but that seems like a complete waste of money to me to pay that much when yes it might look better but is it worth the money probably not also i would like to stay at 22-24" monitor because ive found its the best for FPS gaming reaction time and and you can see everything fine with it so is there a monitor in that size range that isnt $1000? if not then id say 1920 x 1200 for now because the other is just not worth the difference for me Case: the 942 isnt any better? or the hailstorm ones DS offers? and whats with the huge box that anything worth looking into? there is nothing that would be better that DS doesnt offer? tyvm for all of ur answers and anything im asking over again im kind of asking why i like to know info about stuff before i decide i believe everything ur saying and appreciate it i just like to know more and jwing now also depending on what others say and if u answer again i might actually upgrade to a higher res because i thought it would be much more then this idk looks like i might not even need anything to order myself and send to ds and what kind of paint jobs can they do? will they do keyboards and mice as well? maybe even a monitor?
CStormO
Quote Reply Posted: 16 Jan 2011 at 9:46pm |
also what thermal compound is the best and what does DS use?
CStormO
Quote Reply Posted: 16 Jan 2011 at 10:24pm |
thought of a few more things what is the best brand of video card to overclock? i think i remember justin sayin MSI but im not sure if he said its the best to overclock or the easiest because of the MSI after burner program i think its called? also the SSD u said i want the x25-m not e correct? also are the lower sizes just as fast or are the speeds different?
Dragoonseal
DS Veteran Joined: 03 Apr 2009 Online Status: Offline Posts: 2247 |
Quote Reply Posted: 16 Jan 2011 at 10:35pm |
You want the X25-M. You know, the sanely priced one.
The X25-Es are old, discontinued, and never continued to come down in price like they should of. A 40GB Intel SSD will have slightly slower sequential speeds than the 80GB or 160GB models, but sequentials aren't a big deal and for the most part they will perform extremely similar. |
Lilim
Quote Reply Posted: 17 Jan 2011 at 1:02am |
Well to be honest if you have ever seen a good 30" like that dell up close then you would say it is worth the price, that is a great monitor, the price is high because you are getting an ips panel that has great picture quality and you won't get no ghosting or anything like that.
now if that is out of the price range or not something that is what you are looking for then look at the dell Dell UltraSharp U2311H 23 that is a 23" IPS panel with 1920 x 1080 res. Case, I gave you the best case with best airflow, the 942 can have better airflow but you have to add another 200mm fan to the top, if you like the 942 then go for it, I have the hailstorm, great case for LC, airflow is not so great. Mobo: I like evga myself but right now for the SandyBridge cpu all the offer here are asus. PSU: 1. AT 1900 x 1200 you don't even need tri sli, I will reconfig the build to handle the lower res of 1900 x 1200. 2. you don't want quad sli/cf, its scaling is worst then tri sli/cf, in short, if you were at 2560 x 1600 then you would want tri sli/cf cause it beats quad sli/cf. 3. that psu can do tri sli, which is why its in the build. ssd: x25m gen 2 is out now and gen 3 will be out in a couple of month, for reliability and wear and tear those are the ones you want, they are very fast also, they may not be number one in speed but they are right there number 2 or 3, but they are number one in reliability and wear and tear. HDD, I like cache in my HDDs, but the black caviar itself is a afast good drive, anyways if you follow the setup method I posted, the big drive is for storage so its speed is not that important. GPU, as I mentioned earlier, tri sli is for 2560 x 1600, for 1900 x 1200 all you need is one good gpu, you seem like the person that wants to spend extra money on the bells and whistles, so for you we will do dual sli, but is going to be more then you need, to see a difference you have to be in an environment where the difference is noticeable, for example tri sli and dual sli at 1900 x 1200, will not see a difference in most games, at 2560 x 1600 its a different story. I do recommend win7 pro myself, I got ultimate but I got it cause I test stuff so I need to have it, but I like the pro cause it give you xp mode, remote desktop., as long as its the 64bit, I also like the fact that pro sees more ram, home only sees 16GB total, thats system ram and gpu ram combined. Depending on what you want, there are things better that DS offers, but mostly I would say its in the LC area, I would like to see some evga mobos for the SB tho. OK now the build is reconfiged for 1900 x 1200, keep in mind I'm putting sli in this config but my recommendation is for you to go with one gpu and then see if you need a second and add that later, its real easy and could endup saving $400: Here you go Ticket# 479009 --- $3240 (To see this build click here) Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67 Pro (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: AIR: Stage 1: Noctua NH-U12P SE Dual 120mm Fans High Performance Cooler H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty as I said, my recommendation is that you take the above build and remove one 570, and leave the rest alone, that means that your system is ready to go sli anytime, all you do drop in the second gpu if you see you need/want it. |
CStormO
Quote Reply Posted: 17 Jan 2011 at 1:34am |
Case: doing the 942 and upgrading the fan how much cooler would it keep the CPU and do u think it would affect the overclocking much? there is nothing that would be better that DS doesnt offer?(just incase any1 knows anything or can think of anything) also what thermal compound is the best and what does DS use? what is the best brand of video card to overclock? i think i remember justin sayin MSI but im not sure if he said its the best to overclock or the easiest because of the MSI after burner program i think its called? again i want to basically overclock this thing to the max is why im asking these questions over and over tyvm dragoon for answering the SSD questions and DST4ME for all you answered already the questions above havent been answered or ive changed which is why im posting again Edited by CStormO - 17 Jan 2011 at 1:36am |
Quote Reply Posted: 17 Jan 2011 at 1:52am |
Case, CPU temp is mainly due to cpu cooler, case fans here won't mean much to the cpu.
Cpu, SB ocs higher and much easier. Mobo, this is upto you, personally I would wait, but I doubt you could go wrong with either. Ram, 8GB is 4 x 2GB sticks. 1600MHz is all you want/need. Gpu, single 570 will give 50 or higher fps in most games with highest settings, but some people like to cover the minimum, fps some don't notice much of a difference and don't think its worth it, that is why its best you go with one and see if you are happy with one, if not then drop a second yourself down the road when you see you want the extra power. Some games you need sli just to get over 50 fps avarage, so it all depends on what games you gonna play. cpu cooling, D14 is a great cooler but the difference is like 3c or something like that but if you like it, go for it, not sure if it will cover some of your ram access. Display, you can't compare ips panel to tn, ips wins every time, it has better picture quality, which means the screen looks much better then tn panel, its not just the viewing angle, you also don't have to center yourself in front of an ips either, you can be anywhere in the front. when looking at monitor, never pay attention to response time and contrast ratio, there is no real way of measuring them and they are bs numbers, also forget cnet, I never go by any of their reviews, I tend to think they have people that have no idea what they are talking about when it comes to reviews. the dell U2310 is the newer version of the old U2410 which was a great monitor also. As far as performance goes, there is nothing for you to add that DS does not offer to get more performance. best brand to oc IMO Is evga, you use MSI Afterburner to oc and set fan profiles and etc. If you want to oc this thing to the max, I recommend you go stage 4 cooling on cpu, for gaming tho you won't notice a difference over 3.9GHz. I wouldn't oc the gpu if you don't need it, oc the gpu, you have to set its fan to high, and gpu fan on high = loud as heck. |
CStormO
Quote Reply Posted: 17 Jan 2011 at 2:11am |
Memory: k just wondering why tho ive heard 2 conflicting things i heard 3 x 2gb sticks was the best anymore then that is bad for overclocking and ive also heard that anymore then 2 sticks is bad for overclocking? any truth to either of these if the 2 sticks is true then wouldnt 2 x 4gb sticks be a better option
CPU Cooler: hmm any1 else have a idea about this with the ram do u mean it wont fit or that i just cant access it once its in there? if i can have the memory in id probably go for this it isnt much of a difference and the added cooling cant hurt
Display: well response time from what im told 5 and under is all u need U2310 says 6 but that doesnt seem to be bad i mean its 1ms lol ill look into the monitors more... any websites u recommend for looking these things up?
GPUs Overclock: ok that might be exactly what justin said i dont remember and i myself prefer eVGA for anything that they make they seem VERY reliable and so ur saying no need to overclock GPU not much gain here or just because of the fans? i dont mind loud fans in honestly because i game with headphones now obviously no need to make my computer louder if not needed
CPU overclock: ok not this blows my mind why is every1 obsessed with the overclocking if after 3.9 there is no difference i mean i get benchmarks and stuff that people get into but it seems like EVERY1 is overclocking to the max nowdays now if this is the case do i even need the CPU i got or can i get something cheaper and overclock it to that with it being stable enough to maintain gaming sessions of 16+ hours regularly and a lot of them again TYVM for all ur help so far if im asking stuff over and over im not understanding it im not questioning you just wondering |
Quote Reply Posted: 17 Jan 2011 at 2:56am |
Memory: I don't think 8GB will put enough stress on teh controller to matter, above 12GB might make a little difference on the top end of the oc. The x58 platform moved up in 3GB increments, the p55 and p67(SB) move in 2GB increments, but when you saturate the channels its best to do 2 or all 4, so in x58 that would mean 6GB or 12GB and in p67 it would be 4GB or 8GB.
I'm not so sure about the 4GB sticks, I know they are way more expensive, I'm not sure how reliable they are. Cpu cooler, I have not seen the d14 on these mobo yes so I'm not sure how it will endup. Display, As I said before, response time is pure bs, there is no real way of measuring it, closest to it would be white to white, but that would be a huge number so manufacturers don't go by that, instead they go by black to black b2b or gray to gray g2g, cause they produce a smaller number, but that number don't mean nothing, and I mean nothing at all, on top of that, there are different ways of measuring this g2g or b2b and each way will produce a different number, what that means is that we can't even compare numbers from one monitor ot another because we don't know what method was used to do the BS test of g2g or b2b. So whoever told you about response time, does not have proper info, the same goes for contrast, BS. what matters is the quality of the panel, its processor, resolution, Brightness, Color Depth, refresh rate, etc. GPU OC, LOL, you gonna hear those fans thru your headphones,but if you don't mind it, then oc the heck out of those cards, but if you don't notice a difference for your use then drop it back to a mild oc at least, or better yet setup a profile with the high oc you like, and every time you gonna game, load that oc profile first and then afer you are done gaming, load default clocks, that the gpus are not oced all day, and your fans are loud only during gaming. CPU OC, ok IMHO this really is a matter of preference or need, some people just prefer to have a high oc for bragging rights, others are powerusers or benchmarkers, I'm a poweruser, that means I need lot of cpu power/speed cause every bit of it will make my tasks go faster, from folding to encoding and etc, every bit does make a difference in my use, justin is a benchmarker (and a damn good one from what I can tell), every bit of power gives him a higher score, so he needs to squeeze every drop to achieve the highest score, when you get to that level, you gonna want a well balanced system in power from every aspect, psu,mobo,ram,hdd,cpu,cooling etc, they all have to be optimal for him to get the best stable score, as a power user and gamers we can all use a good amount of balance also, but as far as oc goes, gamers won't have much use for oc over 3.9GHz, than you have people that like to brag just to say they have the best or highest, in gaming you won't see much difference pass a certain point, and whatever difference you see in fps, is not gonna be noticeable, there are also people that get a false sense of power/security by getting the most/best/highest. But at the end of the day, we all get one life to live, and if for some unfortunate reason, overkill makes a person happy, then that is the best pc for them, at the end of the day, these pcs get old quick, does not matter what you have today, blink and haswell is here and all these cpus are old and slower, and thats just in 2 years, just 2 years ago i7 came out and we were all existed about the 920, where is it now, look at how much better SB is, and these are not even the high end cpu/platforms of SB, long story short, get what makes you happy, most of us are happy getting most power for our money, some of us are happy getting extras that don't matter, different strokes for different folks OK well I hope that helped you understand better, please ask as many questions as you like. My pleasure and You're welcome Edited by DST4ME - 17 Jan 2011 at 2:58am |
CStormO
Quote Reply Posted: 17 Jan 2011 at 3:10am |
thats what i was wanting to know about the memory ty the cpu cooler i decided i really dont need it like u said its not that much and we dont know if it will fit the display ill have to look into more any recommended sites? gpu overclock lol well if its that loud ill pass on the jet engine
CPU overclock: ok so my question that remains is there a cheaper CPU that will get me to the same point where theres not difference in gaming after?
because if so thats all i need i dont need max frame rates i dont need the max anything i just want to be able to play on full settings of games with no lag and have it look great but all of it being as cheap as possible not that money is a problem but i just dont see the point of spending the extra for the exact reason u said gaming rigs dont last long at the top of the line even tho you have already cut the price of mine down by like 600+ maybe more thats just a guess lol most likely ill wait because of the things you said it might be better to wait and who knows whatelse will come out in the meantime |
Quote Reply Posted: 17 Jan 2011 at 3:47am |
CPU OC, the 2300 or the 2500k will get you to 3.9GHz, but they have 4 cores and 4 threads, the 2600k has 4 cores, 8 threads, this won't mean much to gaming but it does to other things.
Be careful waiting, there is always something else to wait for, for gaming all you do is upgrade the gpu, its the cpu I said that is going to get old, the gpu we can change adn keep up with demand for performance, there is a user in the general section that got a pc about 3 years ago and now wants to upgrade his gpu, and that all he needs, he was smart enough to go with a 850w which easily gave him room to grow and drop in a 570 gtx, once he puts that in, gameing-wise, that pc is gonna feel like a new pc. how is this: Here you go Ticket# 479027 --- $2588 (To see this build click here) Copy of Specifications: Chassis Model: Special Deal Hot Seller - Cooler Master HAF 932 Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 2600K 3.40GHz (Unlocked CPU for Extreme Overclocking) (Quad Core) Motherboard: ASUS P8P67 Pro (Intel P67 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 8GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (80GB Solid State (By: Intel) (Model: X25-M MLC Edition) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Creative Labs X-Fi Titanium Fatal1ty Champion (Includes Front I/O) (PCI-Express Slot Based) Extreme Cooling: AIR: Stage 1: Noctua NH-U12P SE Dual 120mm Fans High Performance Cooler H20 Tube Color:- Not Applicable, I do not have a FrostChill or Sub-Zero LCS Cooling System Selected Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Red) Enhancements: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks Boost Processor: FREE: Overclock the processor between 3.6GHz to 3.9GHz Boost Video Card: - No Thanks, Please do not overclock my video card(s) Boost Memory: - No Thanks, Please do not overclock my memory Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Recovery Tools: Windows Recovery Toolkit (Bundled with Windows 7 CD) Virus Protection: - No Thanks Office: - No Thanks Benchmarking: - No Thanks Install/Test Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Customer Care with 3 Year Limited Warranty if you want to save more money, we can drop the ssd and you can always add that later, all you do is clone the 1TB to your new ssd, and that will move everything over in one shot, no need to install anything. you can follow my clone guide here also if you are sure you won't need to go sli, we can drop the psu to 750w corsair, but I like my options open since I don't know what the future holds, so I always recommend 1000w corsair so that sli is an option, but if you don't want that option we can drop the psu and mobo and save more money, so just tell me what you think. |
justin.kerr
Quote Reply Posted: 17 Jan 2011 at 8:46am |
2 4Gb sticks are nearly the same price as 4 2Gb sticks. +/- $10.00
for mild overclocks on the X58, under 4.2Ghz with 1600Mhz RAM, the amount of RAM won't make any difference 24Gb of RAM is not an issue.
with the Sandy Bridge, 16Gb of RAM is no issue either, and RAM speed has zero effect on the overclock
CStormO
Quote Reply Posted: 17 Jan 2011 at 12:09pm |
ok tyvm and your right i might not even wait now because like you said there is always something else so but all questions answered so heres 1 more then i decide lol
dual booting... i like the freedom of not having to worry about clicking links not worrying about viruses stuff like that but if i do that it sacrafices gaming now granted with this PC a virus might not even handicap me but i dont want to anyhow if i installed Windows 7 just for gaming and then like XP just for surfing if i got a virus on XP would it transfer? if so what about linux or something else? |
Quote Reply Posted: 17 Jan 2011 at 4:43pm |
Infection is something you can't escape, you can't just go around the net and not worry about what link you click, a virus can kill your system, depending on the virus, but make no mistake a good virus/spyware can bring any pc to its knees.
best thing to do is to get a good anti virus like ESET Smart Security, it has a 30 day full free trial, try it first then buy a license after 30 days I love it and highly recommend it. make sure you don't open anything without scanning it. xp won't see all your ram, and I'm not so sure that if you get a rootkit, it won't infect the win7 I just don't think not caring about what you do on the net is a good idea. Just use commonsense, don't open any files downloaded without scanning, and make sure you have a good anit virus/malware that checks your http activity, eset does this. @justin, thanks for clarifying that info, I had not checked but for some reason I remembered the 4GB of sticks being much more expensive, guess I was wrong, how are their reliability? |
CStormO
Quote Reply Posted: 17 Jan 2011 at 5:05pm |
o ok yea i am like that but if its possible for my windows 7 to be safe and have something else to surf with i would definately do that i use AVG free and zonealarm free i also regularly clean my computer with search and destroy bot ccleaner and ad aware i actually can get a free norton internet security that has firewall and everything and i will do that most likely for windows 7
Quote Reply Posted: 17 Jan 2011 at 5:15pm |
eset is lighter and better IMO, I don't go with free apps when it comes to security software, most free apps don't have realtime protection.
also lose spybot and adaware, even both of them together they are not that great, instead either go with spysweeper (shareware) or Malwarebytes (freeware, however, if you want realtime protection for http activity, you need get the shareware version). so in short all you need: 1. commonsense (this accounts for 90% of your protection) 2. eset smart security 3. malwarebytes or spysweeper that combo will keep clean better then anything combo out there. |
CStormO
Quote Reply Posted: 17 Jan 2011 at 5:50pm |
these r all free?
Quote Reply Posted: 17 Jan 2011 at 5:55pm |
nop, only malwarebytes is free but the free version does not do realtime protection, as I said most free security apps dont' do realtime protection of http.
