Cooling Fan Suggestion
Post Date: 2009-08-25
Sodius View Drop Down
  Quote Sodius Quote  Post ReplyReply bullet Topic: Cooling Fan Suggestion
    Posted: 25 Aug 2009 at 10:36am
Can anyone suggest a better cooling fan that would fit into the Proformance 2 prebuild. I know 43c at idle isn't bad but, I am thinking of maybe cooling it down even more. Alex? Sarah? DST4ME? Thanks for any suggestions in advance. By the way my daughters rig is in Nevada and should be here tomorrow at noonish. Yay her! Ermm
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Aug 2009 at 12:30pm
To be honest 43'C is really good.
Even having your system at 5'C IDLE and 20'C load won't make your guys run any faster, or make your system any more stable. The processors are designed to handle temperatures of up to 100'C and if they get too hot, they automatically down clock themselves.
I would honestly leave it alone since it's been tested to work perfectly with your configuration and there really isn't any problem...
  Quote Sodius Quote  Post ReplyReply bullet Posted: 25 Aug 2009 at 1:23pm
Thanks Alex,
That's information I was unaware of. I wasn't thinking running faster or more stable, I was thinking running cooler. Thanks for your reply, you shed some light on the temp that I did not know about. Broken%20Heart
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 25 Aug 2009 at 7:32pm
unless you are above 80 - 85c under load, temp is not an issue for you.
  Quote Alex Quote  Post ReplyReply bullet Posted: 25 Aug 2009 at 7:52pm
I would say for an overclocked system, above 85'C under full load in a 70'C room temperature would be running to the warm side.
For a non-overclocked system, above 80'C under load in a 70'C room temperature would be running to the warm side.
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 26 Aug 2009 at 1:24am
70*C room temp? Damn that must be like living in an oven. ;)
  Quote <8) slunK parade Quote  Post ReplyReply bullet Posted: 26 Aug 2009 at 1:26am
id suggest just opening the side panel and blowing on the heatsink with your mouth
  Quote Sodius Quote  Post ReplyReply bullet Posted: 26 Aug 2009 at 6:16pm
I think I will leave it as is. Temps are very acceptable for sure.Ermm
