geforce rtx 2080 card isnt runningPost Date: 2019-09-10 |
Misterclever0ne
Newbie Joined: 31 Jul 2019 Online Status: Offline Posts: 57 |
Topic: geforce rtx 2080 card isnt running Posted: 10 Sep 2019 at 8:51pm |
I just got my lumos desktop two days ago and I noticed that GeForce rtx 2080 fan or led light isnt running. any help?
HockeyBuck
Quote Reply Posted: 10 Sep 2019 at 11:21pm |
RTX 2080 cards have variable speed fans that can be off at times when GPU use is minimal. You can download EVGA Precision X1 from the EVGA website and have some control over the video card fan speeds and maybe minimal LED control depending on the Brand card. It will show temps on the card as well. Should be able to set fan speeds and be certain if they are working or not.
If the fans are not running at all after all of that, then start the process with DS Support. Edited by HockeyBuck - 10 Sep 2019 at 11:22pm |
Snaike
Moderator Group Just a dude trying to keep the spam away Joined: 23 Jan 2014 Online Status: Offline Posts: 9459 |
Quote Reply Posted: 11 Sep 2019 at 12:22am |
If the card isn't running then you would have no picture? If you mean the fans aren't running make sure to keep an eye on the temp. Programs like HWMonitor and Speccy will watch the GPU temp for you as well.
Misterclever0ne
Quote Reply Posted: 11 Sep 2019 at 4:00pm |
I've got gapghic card geforce rtx 2080 that fans are working but one thing im still struggle with led light not even led light on so far is that common problem? im using evga precision x1
HockeyBuck
Quote Reply Posted: 11 Sep 2019 at 5:26pm |
Not all RTX 2080 will have LED or LED/RGB lights...some brands/models don't. Check out the brand & exact model of the video card you got with that companies website to see what's on board yours. If it does have LED lights they still might not be RGB, and your control over them may be limited to on-off or pulse.
My sons Lumos has the NVidia Founders Edition RTX 2080 and it has just NVidia's green LED lights ...and we only can turn on or off or pulse/fade them using EVGA Precision X1. |
Misterclever0ne
Quote Reply Posted: 12 Sep 2019 at 2:33pm |
yes hockeybuck, u are right.. i just found out that my graphic card dont have led/rgb lights.btw my graphic card is EVGA GEFORCE RTX 2080 Super
Walt101
Newbie Joined: 26 Aug 2019 Online Status: Offline Posts: 5 |
Quote Reply Posted: 12 Sep 2019 at 2:41pm |
Had the same surprised when I noticed that I got an rtx 2070 Super instead of an rtx 2070 |
Nomad1970
Senior Member Joined: 23 Feb 2013 Online Status: Offline Posts: 716 |
Quote Reply Posted: 12 Sep 2019 at 7:25pm |
My EVGA 1080 Ti fans do not run unless I start a game that requires more processing. Just surfing the web or whatnot, they do not run.
My Precious 2
I7-9700 oc 4.7GHz 32GB DDR4 3000MHz Corsair Vengeance RGB Pro SSD M.2 (512GB Samsung 970 PRO) SSD M.2 1TB Samsung 970 EVO 240GB Samsung 860 Pro SSD 1TB W.D. HD EVGA GTX 1080Ti |
HockeyBuck
Quote Reply Posted: 12 Sep 2019 at 9:01pm |
If you feel better running the fans, then just use EVGA Precision X1 software to control the fans speed. It’s a great program.
Misterclever0ne
Quote Reply Posted: 14 Sep 2019 at 5:50pm |
I have afterburner program.
