Help me decide on a build I can’t decide!!!Post Date: 2019-04-21 |
Author | ||
thedemoncowboy
Groupie Joined: 15 Feb 2019 Online Status: Offline Posts: 175 |
Topic: Help me decide on a build I can’t decide!!! Posted: 21 Apr 2019 at 7:58pm |
I can NOT for the life of me decide which is the better route to go!
Bolt X: Red Paint Z390-I Carbon Full liquid cooling GPU/CPU 2080 RTX TI I9 9900 k 700 W PSU 32 GB Vengeance RGB Ram Or Velox X: Black Paint ASUS Hero Full liquid cooling GPU/Silver 2080 RTX TI I9 9900 k 1000 W PSU 32 GB vengeance RGB ram Corsair LL FANS |
Quote Reply Posted: 22 Apr 2019 at 1:41am | |
Like I said in your other poll, I personally like a larger case for airflow, ease of upgrading, etc. You don’t need a 1000 watt psu for a single graphics card.
Cretae
DS Veteran Joined: 22 Mar 2010 Online Status: Offline Posts: 7330 |
Quote Reply Posted: 22 Apr 2019 at 5:56am | |
Agree w/bprat22.
thedemoncowboy
Quote Reply Posted: 22 Apr 2019 at 11:47am | |
See I just like the bolts design better but worried about the 700 W.
I’m worried about just the solid black case I’d they have more issues than painted. I can’t tell what would perform bette |
hoserator
DS Veteran We don't need no stinking "Avatars" ! Joined: 08 Oct 2014 Online Status: Offline Posts: 7965 |
Quote Reply Posted: 22 Apr 2019 at 12:38pm | |
Flip a coin.
Quote Reply Posted: 22 Apr 2019 at 12:45pm | |
Go for what you like. If you like the Bolt then get it. The 700 watt psu is all you need, so no worries there. DS won’t install a gpu/psu combo that doesn’t work. I don’t see the Bolt much smaller, it has grown with each update, and for me, a case with more room for air movement and updates is the way for me. They’ll both perform equally with the same cpu, gpu, ram setup. Edited by bprat22 - 22 Apr 2019 at 12:46pm |
thedemoncowboy
Quote Reply Posted: 22 Apr 2019 at 12:49pm | |
So if I overclock should I go velox ? Or bolt? I love the look of bolt but if the velox performs better then... |
Quote Reply Posted: 22 Apr 2019 at 1:23pm | |
You or DS can safely overclock the Bolt, and there is an option for it. But, the 9900k Turbos to 5.0 anyways, so unless your into demanding productivity apps, the stock speed is all you need. Same for graphics card. Overclocking does put the speed on all cores, vs Turbo that steps the speed over all cores, but for gaming, 2-4 cores is great.
If you wanted to push the overclock to higher speeds, for bragging rights , fun or benchmarking, then the larger case gives you more room for the heat overclocking generates. |
thedemoncowboy
Quote Reply Posted: 22 Apr 2019 at 1:25pm | |
What’s the best route then? |
Quote Reply Posted: 22 Apr 2019 at 1:31pm | |
For me, the Velox. For you? That’s your decision. If you want me to make the decision for you, with no liability or repercussions. , then go Velox.
We’ve mentioned this to others....the Velox has the window on the right side, the Bolt and Lumos on the left. For some like me, the placement of the pc next to my desk made the Lumos the best pick. |
thedemoncowboy
Quote Reply Posted: 22 Apr 2019 at 1:43pm | |
I had the lumos but had issues with it. So I liked it was on right side of me which would be bolt x but if the velox is that much better performance wise |
Quote Reply Posted: 22 Apr 2019 at 3:22pm | |
I didn’t say the Velox was better performance. With the same components, they are equal. It comes down to a personal preference in the case, either for looks or the Bolt if you have a space issue.
thedemoncowboy
Quote Reply Posted: 22 Apr 2019 at 3:33pm | |
If it’s safe I would OC To stage one but can’t tell which the better route is and which will perroma better |
Quote Reply Posted: 23 Apr 2019 at 2:14am | |
I guess I would follow hoserator’s advice and flip a coin. Can’t go wrong with either choice. What do you want to look at for the next 3-5 years?
Good luck. |
thedemoncowboy
Quote Reply Posted: 23 Apr 2019 at 6:12am | |
I love the bolt lol but the velox is nice too. I love the lumos but just it’s not digital storm branded any more and feel the need to go their rite |
thedemoncowboy
Quote Reply Posted: 23 Apr 2019 at 5:15pm | |
I decided red velox
Alex
Quote Reply Posted: 23 Apr 2019 at 5:36pm | |
hoserator
Quote Reply Posted: 23 Apr 2019 at 5:58pm | |
Nice! Now the waiting starts.
thedemoncowboy
Quote Reply Posted: 23 Apr 2019 at 6:05pm | |
Sent you an email Alex whenever you get to it. Thanks again |
thedemoncowboy
Quote Reply Posted: 23 Apr 2019 at 6:06pm | |
This is a rebuild hopefully goes quicker this time around! |
thedemoncowboy
Quote Reply Posted: 23 Apr 2019 at 6:26pm | |
Quote Reply Posted: 24 Apr 2019 at 1:57am | |
Nice pick.
Cretae
Quote Reply Posted: 24 Apr 2019 at 6:01am | |
thedemoncowboy
Quote Reply Posted: 24 Apr 2019 at 11:52am | |
Alex |
