Help with a "Budget" Build for a friend.Post Date: 2016-11-13 |
Discoern
Newbie Joined: 15 May 2011 Online Status: Offline Posts: 27 |
Topic: Help with a "Budget" Build for a friend. Posted: 13 Nov 2016 at 9:42am |
My friend wants to get his son a Gaming PC for Christmas and I of course recommended he come here! Well, lets see your best builds around $2000-2500. Keep in mind future upgrade-ability!
Ready.....GO! Budget: $2000-2500 Expectations: Single Monitor 1920x1080 Usage: Latest FPS (BF1..etc.), web surf, school projects (microsoft office) Special Needs: The most bang for the buck, ability to upgrade further. Saved Ticket #: 1521172 Specifications: Z170 Chipset Motherboard vs. X99 Chipset Motherboard 480GB SSD Digital Storm vs. 500GB Samsung 850 EVO SSD Edited by Discoern - 13 Nov 2016 at 9:53am |
Snaike
Moderator Group Just a dude trying to keep the spam away Joined: 23 Jan 2014 Online Status: Offline Posts: 9459 |
Quote Reply Posted: 13 Nov 2016 at 10:22am |
(Request granted)
Quote Reply Posted: 13 Nov 2016 at 11:09am |
Here's an alternate to your build, but with...
A better psu for additional $34. Gold vs bronze efficiency and double the warranty and fully modular wiring. Better gtx 1070...EVGA and zero fan rpm under 60C. Better SSD and HDD. The Western Digital is better for reliability and warranty. The Samsung EVO has its own warranty and not the branded DS with only their warranty, plud you know what your getting. Better cooler. Again not the DS branded, but Corsair and their warranty beyond DS's. Configuration Code: 1521238 Total Price with Instant Savings: $2,345.00 Direct Load URL: https://www.digitalstorm.com/configurator.asp?id=1521238 Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Apollo (White) Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 6700K 4.0GHz (Codename Skylake) (Unlocked CPU) (Quad Core) Motherboard: ASUS Z170-PRO GAMING (Intel Z170 Chipset) (Up to 5x PCI-E Devices) System Memory: 16GB DDR4 2666MHz Digital Storm Performance Series Power Supply: 750W EVGA SuperNOVA <br><strong></strong> Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD (500GB Samsung 850 EVO) <br><strong></strong> Storage Set 2: 1x Storage (1TB Western Digital - Black Edition) <br><strong></strong> Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce GTX 1070 8GB (EVGA ACX 3.0) (VR Ready) <br><strong></strong> Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Corsair H115i - 280mm Liquid CPU Cooler (Fully Sealed + No Maintenance) <br><strong></strong> HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stage 1: Overclock CPU - Up to 4.4GHz (Depends on Cooling and Motherboard) <br><strong></strong> Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Professional (64-Bit Edition) Recovery Tools: Factory Reset Feature (Restore Windows + Drivers) (Partition up to 25GB of Storage) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Quote Reply Posted: 13 Nov 2016 at 1:42pm |
bp gave you the best config there.
Kyser13th
Newbie Joined: 25 Oct 2016 Online Status: Offline Posts: 62 |
Quote Reply Posted: 13 Nov 2016 at 7:20pm |
Stick with the Z170 Chipset rather then the X99 Chipset Motherboard. Z170 is running off the most current processor generation Skylake whereas the X99 Broadwell-E's are indeed powerful, but their format is on the way out. While there is a possibility that Kabylake will be compatible with Z170 boards, as evident by some bio updates for the upcoming format, it's still somewhat to be seen what Kabylake really brings to the table. The i7-6700k is one of those legendary processors and will get the job done.
Edited by Kyser13th - 13 Nov 2016 at 7:21pm |
Quote Reply Posted: 13 Nov 2016 at 9:49pm |
Kabylake (7700k) will be a little better than 6700K you could probably oc it to 4.7 easy vs 4.4 easy on the 6700k, aka we could see 700k at 5.0GHz with good vcore, but that is not too far off of 4.7GHz on 6700k with good vcore. Not that big of a deal to wait for.
As mentioned the x99 is the old platform, however it does currentlhy offer more than 4 cores, but for gaming 4 cores is more than enough, you only go higher on cores if you have some apps that use it like heavy media editing or other apps that actually have use for more than 4 cores. so for games you want to be on the z170 and for power use you want to be on x99 for now. Edited by DST4ME - 13 Nov 2016 at 9:52pm |
