Need HelpPost Date: 2009-11-24 |
| Author | |
Mr.Blue
Joined: 24 Nov 2009 Online Status: Offline Posts: 11 |
Topic: Need HelpPosted: 24 Nov 2009 at 9:52pm |
Hi,
I am new at building gaming computers and I was wondering was stuff I need for building a good gaming computer? < id="gwProxy" ="">< ="jsCall;" id="jsProxy" =""> |
Sodius
Joined: 18 Jan 2009 Online Status: Offline Posts: 613 |
Posted: 24 Nov 2009 at 9:58pm |
To get this started you will to let us know what resolution you will be gaming at and what your budget is for starters.
Mr.Blue
Posted: 24 Nov 2009 at 10:08pm |
I want a good resolution, don't worry about the budget because half price of all will be Christmas gift. LoL< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
Posted: 25 Nov 2009 at 5:49am |
If you gonna build yourself, get ready for some headache and lot of trouble shooting
but building the pc itself is very fun, the bsods and other problems that come afterwards are not fun
but like Sodius said, we need to know your resolution, good resolution to you might be different to us. |
Mr.Blue
Posted: 25 Nov 2009 at 1:41pm |
what resolution you have?< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
justin.kerr
Joined: 06 May 2008 Online Status: Offline Posts: 5084 |
Posted: 25 Nov 2009 at 1:49pm |
you want to play at your monitors native resolution.
Most monitors are close to this.
28"-30" 2560x1600
24"-26" 1920x1200
22" 1680x1050
some will vari from this, but they will be close
Mr.Blue
Posted: 25 Nov 2009 at 4:25pm |
my screen resolution is 1280 x 1024< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
Posted: 25 Nov 2009 at 6:48pm |
well telling you what gpu to get for 1200 x 1000 and higher res are gonna be different, so you want us to config a system for 1200 x 1000 res?
Mr.Blue
Posted: 25 Nov 2009 at 10:45pm |
if it is the best yeah< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
Posted: 27 Nov 2009 at 1:10am |
the higher the resolution the better the details.
1200 x 1000 is the lowest res, 1900 x 1200 is a good/great res, 2560 x 1600 is the best res between those 3 resolutions. of course at 2560 x 1600 you are looking at a 30" monitor and that monitor will cost $1200 or more. I'm thinking you are a big confused about how resolution works. your resolution is whatever your monitor can do. having said all that, you want us to config a system for a monitor that has 1200 x 1000 resolution or are you planing on getting a newer/bigger monitor that will have a higher res? if you are getting a new monitor with a higher res then please let us know the resolution/size of that monitor, so we can give you the right configuration. if you are still confused then ask as many questions as you like. |
Mr.Blue
Posted: 29 Nov 2009 at 12:14am |
I have a 19" monitor. I wanna build a gaming computer. Can you tel me what processor, memory, hard drive, graphic card, etc should I buy? < id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
Posted: 29 Nov 2009 at 7:54am |
19" monitor probably means 1600 x 1200 res.
Copy of Specifications: Chassis Model: Cool Master - HAF 932 Exterior Finish: - Not Available Interior Finish: - Not Available Trim Accents: - Not Available Processor: Intel Core i7 920 2.66GHz (Quad Core) Motherboard: EVGA X58 LE Edition SLI (Intel X58 Chipset) (Supports SLI or CrossFire) System Memory: 6GB DDR3 1600MHz Digital Storm Certified by mushkin enhanced (Highly Recommended) (Hand Tested) Power Supply: 750W Corsair TX (Dual SLI Compatible) Card Reader: - Not Available Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM) (SATA) Set 1 Raid Options: - Not Available Hard Drive Set 2: Multimedia\Data: - No Thanks Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD±R/RW/CD-R/RW (DVD Writer 20x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 1x ATI Radeon HD 5850 1GB Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: AIR: Stage 2: Noctua NH-U12P High Performance Cooler (Compatible With ONLY i7 Processors) Liquid Color:- Not Available Chassis Airflow: Standard Factory Chassis Fans Internal Lighting: Internal Chassis Lighting System (Blue) Enhancements: - Not Available Chassis Mods: - Not Available Boost Processor: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade) Boost Video Card: - Not Available Boost Memory: - Not Available Tweak Windows: - Not Available Windows OS: Microsoft Windows 7 Professional (64-Bit Edition) Restore Kit: Digital Storm Specialized Recovery System (DVD Image Based) Virus Protection: - Not Available Office: - Not Available Benchmarking: - Not Available Install/Test Game: - Not Available LCD Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: - No Thanks Mouse: - No Thanks External Storage: - No Thanks Exclusive T-Shirt: - No Thanks Priority Build: - No Thanks, Ship Within 5-10 Business Days After Order Is Successfully Processed Warranty: 3 Year Platinum Care Extended Parts & Labor Warranty if you don't care about dx11 support you can change the gpu to 275 gtx. if you see yourself going tri sli in the future then change the psu to 1000w corsair. Edited by DST4ME - 29 Nov 2009 at 8:01am |
Sodius
Posted: 29 Nov 2009 at 11:56am |
Nice setup DST4ME, that rig is awesome and has room for future upgrades. The 932 case is awesome for airflow and I am continuely amazed at how cool my machine runs.
Posted: 29 Nov 2009 at 12:20pm |
Ya I love the haf
