PC power light troublesPost Date: 2022-04-21 |
Post Reply ![]() |
1sarina ![]() Newbie ![]() Joined: 21 Apr 2022 Online Status: Offline Posts: 1 |
![]() ![]() ![]() Posted: 21 Apr 2022 at 3:01am |
I can fully turn on my PC and the LEDs work but the PC won't display anything and the power buttons light flashes white. I can't figure it out and I have used sit resources and looked up information https://mobdro.onl/ https://vidmate.onl/.
Edited by 1sarina - 14 May 2022 at 4:01am |
hoserator ![]() DS Veteran ![]() We don't need no stinking "Avatars" ! ![]() Joined: 08 Oct 2014 Online Status: Offline Posts: 7078 |
If your pc has a dedicated video card (gpu) the monitor has to be connected to it and not the motherboard (mobo). When installed, the mobo disables its video outputs in the I/O plate and all graphics come out of the gpu. Very common mistake. Hope that is all. Good luck. ![]() |
Nomad1970 ![]() Senior Member ![]() ![]() ![]() Joined: 23 Feb 2013 Online Status: Online Posts: 624 |
A flashing power button light means the computer is in sleep or hibernate. Pressing a key on the keyboard should wake it up
My Precious 2
I7-9700 oc 4.7GHz 32GB DDR4 3000MHz Corsair Vengeance RGB Pro SSD M.2 (512GB Samsung 970 PRO) SSD M.2 1TB Samsung 970 EVO 240GB Samsung 860 Pro SSD 1TB W.D. HD EVGA GTX 1080Ti |
Post Reply ![]() |
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You can vote in polls in this forum |
