SSD Help Corsair VS Samsung??Post Date: 2014-04-03 |
Author | ||
gifty101
Newbie Joined: 03 Apr 2014 Online Status: Offline Posts: 1 |
Topic: SSD Help Corsair VS Samsung?? Posted: 03 Apr 2014 at 11:35am |
I was just informed the my Vanquish was built without the Corsair Neutron GTX Series 120GB SATA 6Gbps due to out of stock. I talked with a tech and it sounded like they replaced it with a Samsung 840 EVO 120GB. I am scared that I am paying the same price for a down Grade. I want to know which is the Better SSD the Corsair Vs. the Samsung???
ArkansasWoman777
Quote Reply Posted: 03 Apr 2014 at 11:50am | |
A lot of people on here have been recommending the Samsung SSD as the best but i think either of the two are good
Quote Reply Posted: 03 Apr 2014 at 2:39pm | |
Testing I've seen shows the Samsung EVO faster across the board in most but not all areas. But,like Arkansas said, they're all fast and for most, not noticeable. Dependability, time will tell.
DS substitutes the same as much as possible. |
Meller
Quote Reply Posted: 03 Apr 2014 at 3:21pm | |
EVO's have a known write issue on several of their SSD versions. I got luck with my two 1tb's to not have it. But hands down, the 840 PRO 256GB and higher are the best there are. It is what it is. Samsung 840 PRO is you want the absolute best.
Custom PC
Counsel
Groupie Joined: 29 Sep 2013 Online Status: Offline Posts: 125 |
Quote Reply Posted: 06 Apr 2014 at 9:29am | |
As it happens, both products are featured on Anandtech's SSD bench. You can pull up a comparison of the two here: http://www.anandtech.com/bench/product/703?vs=966 As you can see, they're fairly close on most tests, though the EVO blows the Neutron away on certain very specific tests. Like most Samsung SSDs, the EVO has a pretty good reputation for reliability. The EVO and Neutron are also targeted at a very similar price point, though Samsung have been doing some aggressive discounting in the past few months. Overall, I wouldn't be concerned. These two are very close equivalents for almost all intents and purposes. I'd be very surprised if the substitution had any negative effect on your system. |
Alex
Quote Reply Posted: 06 Apr 2014 at 4:29pm | |
We would never change a configuration to a different component unless it was just as good or better.
Meller
Quote Reply Posted: 06 Apr 2014 at 5:27pm | |
Don't buy the 120GB. Regardless of synthetic benchmarks or proposed speeds, you get a better read/write on the 250gb+ sizes. Same for the pro's. The 256gb and up are twice as fast as the 128gb.
Custom PC
Snaike
Moderator Group Just a dude trying to keep the spam away Joined: 23 Jan 2014 Online Status: Offline Posts: 9448 |
Quote Reply Posted: 07 Apr 2014 at 1:38am | |
Meller, gifty101 has purchased the Vanquish II (as did I). There is no choice in type or size of components due to the 'pre-configured' state of this line of computers. Offering advice that can't be taken is of little use. Now, on the other hand, should he wish to upgrade in the future there is plenty of room to move into the higher Gb SSDs. But if DS says that it's the same or better, I would not be concerned in the least. **Edit... Misspelled gifty101 Edited by Snaike - 08 Apr 2014 at 2:23am |
Snaike
Quote Reply Posted: 07 Apr 2014 at 1:45am | |
BTW, Welcome to the family gifty101! Hope you enjoy your Vanquish. Great little budget beating beasts that they are.
fstcvc
DS Veteran Joined: 06 Jul 2013 Online Status: Offline Posts: 2551 |
Quote Reply Posted: 07 Apr 2014 at 8:35am | |
Congrats on your new rig and welcome to DS!!
As already repeated several times, you'll be more than happy with the EVO drive installed and Samsung has a great track record with their SSDs. |
i7 4770K @ 4.5GHz Asus Maximus VI Extreme 16GB Corsair Dominator Platinum 3xSLI EVGA SuperClocked GTX TITAN Samsung 840Pro SSD 256GB+512GB HydroLux+XSPC CPU/MoBo/GPU Liquid Cooling |
Meller
Quote Reply Posted: 07 Apr 2014 at 3:20pm | |
I realize that. I already provided him with opinions on brands. From this point on, I'm merely pointing out specs. Everything is always of use. Thanks for your concern though, I appreciate your input *cough* Have a nice day. Edited by Meller - 07 Apr 2014 at 3:20pm |
Custom PC
