What kind monitor is best for pc gamingPost Date: 2019-07-31 |
Misterclever0ne
Newbie Joined: 31 Jul 2019 Online Status: Offline Posts: 57 |
Topic: What kind monitor is best for pc gaming Posted: 31 Jul 2019 at 9:43am |
Hello everyone. Im exciting to get my digital storm lumos deaktop coming soon. Im wondering what kind monitor best for pc gaming graphic? Feedback will be appreciated thanks
Dondomingo
Newbie Joined: 31 Jul 2019 Online Status: Offline Posts: 41 |
Quote Reply Posted: 31 Jul 2019 at 10:02am |
Generally you’ll want something that has a high refresh rate in Hz (and low response time in milliseconds (Ms). So many brands and sizes to choose from that fits your needs.
My space is limited so my screen is 27” flatscreen and is 144Hz refresh and 1Ms response time. Don’t buy a curved monitor unless you are buying something BIG. Small screens you’ll loose the curved visual effect. Unless your face is is right up in it. My TV is a 60” curved, so I get the full visual effect. Edit: I did want to add I had a bad experience with a Sharp brand monitor and bad customer service. Edited by Dondomingo - 31 Jul 2019 at 10:04am |
Misterclever0ne
Quote Reply Posted: 31 Jul 2019 at 12:39pm |
What about 4k and HDR?
Dondomingo
Quote Reply Posted: 31 Jul 2019 at 1:41pm |
If your budget and video card support it, I would never turn one down 4K for crisp images of four times the normal pixel amount, yet there is more detail and contrast they say with HDR or the best of both worlds with the 4K UHD.
They can run you from 300.00 to 1000.00 plus depending on what you want. I should have gotten a better monitor myself, my 2070 will support it, but I spent so much on the PC build tbh I totally ignored the subject. it’ll have to wait, besides I’m replacing my old 60Hz monitor lol so it’s an upgrade. Regardless just remember no matter what higher the Hz and lower the Ms the better. I’d love to have a ASUS ROG Swift PG27UQ 27" but that runs $1.7k Edited by Dondomingo - 31 Jul 2019 at 2:03pm |
Misterclever0ne
Quote Reply Posted: 31 Jul 2019 at 2:29pm |
Yeah too expensive. But im think about to go for ASUS ROG Swift PG348Q seem good one monitor with 100hz so 144hz is better? Let me know thanks
Dondomingo
Quote Reply Posted: 31 Jul 2019 at 3:00pm |
That’s definitely a nice monitor, 100hz is for all intent better than 60Hz monitors, yet I couldn’t find its response time listed. So I’ll assume though it’s in the 2-4 range. Still a nice monitor if you find it fits your budget.
In a nutshell 100Hz over a 144hz “probably” wouldn’t be to noticeable by the naked eye compared going from 60 to 100hz unless your playing some extreme FPS and have twitch reflexes. Even then. It can get subjective. That’s the thing that bothers me about some of these monitors out there. Some list at $600 for 4K/HDR/UHD but when you read the fine print they have like 60Hz and 12 Ms response times. Another thing to keep in mind is that as sweet 4K etc is, it still can reduce performance if your PC isn’t up to par to push out that much graphics and speed under load. Hence why a fast 1080p and WQHD are still popular even in the current market. Now you have me thinking of returning the new monitor and spending a few extra bucks...thanks. Edited by Dondomingo - 31 Jul 2019 at 3:18pm |
hoserator
Quote Reply Posted: 31 Jul 2019 at 3:56pm |
Welcome to DS and congratulations on getting a Lumos. What did you order inside? To get the Verified Customer badge you have to write your name the saMe As the order, I think. The speed of the monitor is important but do not disregard the type of panel used. I prefer the color rendition of IPS vs TN (and the greater viewing angle) but they are a bit slower (not that you would notice.) The sweet spot IMO is the 2K (1440) resolution. That PG27U (4K) is a hell of a monitor and also pricey. You would need a 2080Ti to make it perform well. Also, depending on the gpu you ordered; if Nvidia based make sure that the monitor you end up getting is GSync and if AMD, FreeSync.. Those are made specially to work with their respective gpu tech. Enjoy.
Misterclever0ne
Quote Reply Posted: 31 Jul 2019 at 5:36pm |
Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i9-9900K (5.0 GHz Turbo) (16-Thread) (8-Core) 3.6 GHz Motherboard: MSI MPG Z390 GAMING PRO CARBON AC (Intel Z390 Chipset) (Up to 3x PCI-E Devices) System Memory: 16GB DDR4 3000MHz Corsair Vengeance RGB Pro (RGB Light Bar) Power Supply: 850W Corsair RM850x (Fully Modular) Expansion Bay: - No Thanks Optical Drive: - No Thanks Storage Set 1: 1x SSD M.2 (500GB Digital Storm M.2 Performance Series) Storage Set 2: 1x Storage (2TB Seagate / Toshiba / Hitachi) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless PCI-E ASUS PCE-AC56 (Supports 802.11ac) Graphics Card(s): 1x GeForce RTX 2080 SUPER 8GB (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (Dual Fan) (Fully Sealed + No Maintenance) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair LL Series (RGB Fans) (Software Controlled Effects) Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: Option Not Available CPU Boost: Stage 1: Overclock CPU - Up to 4.7GHz on All CPU Cores Graphics Boost: Yes, Overclock the video card(s) as much as possible with complete stability OS Boost: - No Thanks, Please do not tweak the services on the operating system Operating System: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: USB Drive - Windows 10 Installation (Format and Clean Install) Virus Protection: Windows Defender Antivirus (Built-in to Windows 10) Office: - No Thanks Mouse Pad: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: Digital Storm MasterKeys Lite Bundle (RGB) Keyboard & Mouse Mouse: - No Thanks Branded Gear: - No Thanks Thats what i ordered it to put in lumos desktop. |
hoserator
Quote Reply Posted: 01 Aug 2019 at 1:41am |
Nice. Be aware that for storage M.2 is a form factor and that the Pcie interface is way faster than SATA. The DS ssd you have selected is SATA. You can request a change if early and it matters. |
Cretae
DS Veteran Joined: 22 Mar 2010 Online Status: Offline Posts: 7328 |
Quote Reply Posted: 01 Aug 2019 at 5:11am |
I agree you will be happier with a Samsung 970 EVO m.2 NVMe drive as drive 1. ~5x faster than SATA.
I also agree an IPS panel is far superior for color saturation and display angles. The monitor you have selected will play very nicely with your GPU, and it won't need any overclocking. The gain is very small in exchange for more heat and stress. Be advised ultra-wide is not for everyone. Many games will not display in widescreen, either stretching the image or leaving you with dark bands on both sides. Same with video content. This website will provide you with a wide variety of monitors that are G-Synch enabled: https://www.nvidia.com/en-us/geforce/products/g-sync-monitors/specs/ Hope it helps. Edited by Cretae - 01 Aug 2019 at 5:15am |
Misterclever0ne
Quote Reply Posted: 01 Aug 2019 at 8:03am |
Thank you for your help about change ssd. I already e mail them to please change my previous ssd to ssd 500gb samsung 970 evo m.2 nvm.
Dondomingo
Quote Reply Posted: 01 Aug 2019 at 8:37am |
That would be the second person in one day hoserator saved from sata speeds in one day
Cretae
Quote Reply Posted: 01 Aug 2019 at 8:53am |
That's the hoser! |
Misterclever0ne
Quote Reply Posted: 01 Aug 2019 at 8:57am |
Uruvsuurt
Groupie Joined: 02 Sep 2009 Online Status: Offline Posts: 135 |
Quote Reply Posted: 01 Aug 2019 at 11:42am |
After spending months looking at monitors, I found the the Dell S-Series 27" (S2719DGF) was my best bang for the buck.
The ROG series monitors are awesome, especially the IPS panels, but the price is just stupid. The Dell is 144Hz, 1440p, 1ms, and under $300. I believe I bought mine for around $270 on sale. The panel is a TN, but I really don't see much of a difference overall between this Dell and my older 23" IPS monitor. Yes the colors are better on an IPS, but it is not drastically different. I have to put them side by side to really see it. I did have to fiddle with the settings more on the TN to get the solid picture, where as the IPS was good right out of the box. The faster Hz and 1440p easily makes up for any color issues. I also am the only person playing the games so viewing angle isn't an issue. The monitor is built very well, and feels like a premium grade. Plenty of USB ports, HDMI, Displayport, Etc. yes there are better monitors, but for what you get, and at the price, the Dell meets every check box I had. |
Misterclever0ne
Quote Reply Posted: 01 Aug 2019 at 5:23pm |
Here is what i changed
Chassis Model: Digital Storm Lumos Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i9-9900K (5.0 GHz Turbo) (16-Thread) (8-Core) 3.6 GHz Motherboard: MSI MPG Z390 GAMING PRO CARBON AC (Wi-Fi) (Intel Z390 Chipset) (Up to 3x PCI-E Devices) System Memory: 16GB DDR4 3000MHz Corsair Vengeance RGB Pro (RGB Light Bar) Power Supply: 850W Corsair RM850x (Fully Modular) Expansion Bay: - No Thanks Optical Drive: - No Thanks Storage Set 1: 1x SSD M.2 (500GB Samsung 970 EVO) (NVM Express) Storage Set 2: 1x Storage (2TB Seagate / Toshiba / Hitachi) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Graphics Card(s): 1x GeForce RTX 2080 SUPER 8GB (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: H20: Stage 2: Digital Storm Vortex Liquid CPU Cooler (Dual Fan) (Fully Sealed + No Maintenance) HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Corsair LL Series (RGB Fans) (Software Controlled Effects) Internal Lighting: Remote Controlled Advanced LED Lighting System (Multiple RGB Color Modes) Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: Option Not Available CPU Boost: Stage 1: Overclock CPU - Up to 4.7GHz on All CPU Cores Graphics Boost: Yes, Overclock the video card(s) as much as possible with complete stability OS Boost: - No Thanks, Please do not tweak the services on the operating system Operating System: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: USB Drive - Windows 10 Installation (Format and Clean Install) Virus Protection: Windows Defender Antivirus (Built-in to Windows 10) Office: - No Thanks Mouse Pad: - No Thanks Display: - No Thanks Surge Shield: - No Thanks Speakers: - No Thanks Keyboard: Digital Storm MasterKeys Lite Bundle (RGB) Keyboard & Mouse Mouse: - No Thanks Branded Gear: - No Thanks |
hoserator
Quote Reply Posted: 02 Aug 2019 at 1:49am |
Good choices all. Enjoy. Monitor viewing is quite subjective so ..... |
oldlady RPGer
DS Veteran One of the cool kids Joined: 09 Sep 2011 Online Status: Offline Posts: 1080 |
Quote Reply Posted: 05 Aug 2019 at 3:28pm |
LG 32GK850G-B 32" QHD Gaming Monitor with 144Hz Refresh Rate and NVIDIA G-Sync.
Love it and zero issues. |
Misterclever0ne
Quote Reply Posted: 08 Aug 2019 at 11:51am |
i found gaming monitor thats what i want! here is ASUS ROG Swift PG279Q 27" WQHD G-SYNC Gaming Monitor
hoserator
Quote Reply Posted: 08 Aug 2019 at 11:55am |
That is a very nice monitor and favorite around here. (me included) You will love it.
Misterclever0ne
Quote Reply Posted: 08 Aug 2019 at 12:31pm |
Great i bet i will love it! Thanks for help feedback and i did make a good choice of gaming monitor!
DSmithz
Newbie Joined: 18 Sep 2019 Online Status: Offline Posts: 3 |
Quote Reply Posted: 18 Sep 2019 at 5:45am |
I would say BENQ 24" XL2411z/p. (I have the XL2411z, no displayport sadly.) Also I've heard that the ASUS VG248QE 24" is pretty good too.
Threetall
Newbie Joined: 26 Aug 2015 Online Status: Offline Posts: 49 |
Quote Reply Posted: 20 Sep 2019 at 6:29am |
A monitor should outlast a couple builds so feel free to splurge now because you will be saving later.
