WIFI not workingPost Date: 2018-02-21 |
nickp100
Newbie Joined: 17 Mar 2016 Online Status: Offline Posts: 17 |
Topic: WIFI not working Posted: 21 Feb 2018 at 8:50pm |
I have the bolt 3 model with the Aus motherboard , 4.0Ghz intel processor and a GTX 980ti running windows 10.
It seems that after the Tues Windows update, i don’t even get the option to select any wireless network as if the adapter is non existent. It does not see any wireless networks at all. Does anybody else have the same problem. Any ideas how to rectify? Thanks |
Quote Reply Posted: 22 Feb 2018 at 2:08am |
You might have to go to Asus website and download and install the latest drivers for the WIFI.
First try shutting the Bolt down, unplug for a minute or so, plug back in and see if it helps. Sometimes a simple boot gives the files the needed kick to initiate. |
