advice and opinionPost Date: 2017-10-04 |
gravity
Newbie Joined: 04 Oct 2017 Online Status: Offline Posts: 3 |
Topic: advice and opinion Posted: 04 Oct 2017 at 3:07am |
First of forgive my noobness this is a build for my fiance and tbh its my first time delving into stuff like this she plays alot of games and prefers higher quality graphics im relly just looking for changes or advice on changes and opinions shes not realy interested in overclocking either if that helps
Budget: 2200$ Expectations: not really sure Usage: gameing Special Needs: [Please Type Here] Saved Ticket #: (im guessing this means the config code) 1753876 Specifications: Specifications: Chassis Model: Special Deal Hot Seller - Digital Storm Lumos <br><strong></strong> Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7-7700 (Turbo Up to 4.20 GHz) (Codename Kaby Lake) (Quad Core) (Not Overclockable) <br><strong></strong> Motherboard: ASUS PRIME Z270-P (Intel Z270 Chipset) (Up to 2x PCI-E Devices) (No SLI Support) <br><strong></strong> System Memory: 16GB DDR4 3000MHz Digital Storm Performance Series <br><strong></strong> Power Supply: 750W EVGA SuperNOVA (750 B1) (Semi Modular) <br><strong></strong> Expansion Bay: - No Thanks Optical Drive: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) (Internal) Storage Set 1: 1x SSD M.2 (250GB Digital Storm Performance Series) Storage Set 2: 1x Storage (2TB Seagate / Toshiba) Storage Set 3: - No Thanks RAID Config: - No Thanks RAID Card: - No Thanks Internet Access: Wireless PCI-E ASUS PCE-AC56 (Supports 802.11ac) <br><strong></strong> Graphics Card(s): 1x GeForce GTX 1060 6GB (VR Ready) Sound Card: Integrated Motherboard Audio HPC Processor: - No Thanks Extreme Cooling: AIR: Stage 1: High-Performance Copper Heat Pipe Cooler <br><strong></strong> HydroLux Tubing Style: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected HydroLux Fluid Color: - Not Applicable, I do not have a custom HydroLux liquid cooling system selected Cable Management: Premium Cable Management (Strategically Routed & Organized for Airflow) Chassis Fans: Standard Factory Chassis Fans Internal Lighting: - No Thanks Airflow Control: - No Thanks Chassis Mods: - No Thanks Noise Reduction: - No Thanks LaserMark: - No Thanks Boost Processor: Stock Factory Turbo Boost Advanced Automatic Overclocking Boost Graphics Card(s): - No Thanks, Please do not overclock my video card(s) Boost OS: - No Thanks, Please do not tweak the services on the operating system Windows OS: Microsoft Windows 10 Home (64-Bit Edition) Recovery Tools: Factory Reset Feature (Restore Windows + Drivers) (Partition up to 50GB of Storage) Virus Protection: FREE: McAfee AntiVirus Plus (1 Year Service Activation Card) (Not Pre-installed) ($35 Value) Office: - No Thanks Game: - No Thanks Display: Asus 23.8 inch VN248H-P (Slim Bezel) (IPS Display) (1920x1080) <br><strong></strong> Surge Shield: APC SurgeArrest Personal PER7 (7 Outlet) 120V Surge Protector <br><strong></strong> Speakers: Logitech 2 Piece (Black Edition) Amplified Speaker Set <br><strong></strong> Keyboard: CM Storm Octane Bundle (7 LED Colors) (Gaming Keyboard & Gaming Mouse) <br><strong></strong> Mouse: - No Thanks Branded Gear: - No Thanks Priority Build: - No Thanks, Ship Within 10-15 Business Days After Order Is Successfully Processed Warranty: Life-time Expert Care with 3 Year Limited Warranty (3 Year Labor & 1 Year Part Replacement) |
Snaike
Quote Reply Posted: 04 Oct 2017 at 9:11am |
What resolution are you looking to be gaming on? 1080? 4K? This information will help the configuration gurus get to the best system for your needs.
gravity
Quote Reply Posted: 04 Oct 2017 at 9:36am |
we dont need anything like 4k, just about anything is fine because anything we can get is a improvement over what she has now which is a laptop from like 2010
Edited by gravity - 04 Oct 2017 at 9:43am |
FR3SHM3AT
Groupie Joined: 12 Feb 2011 Online Status: Offline Posts: 494 |
Quote Reply Posted: 04 Oct 2017 at 11:51am |
Great Config. I would up the GPU to a 1070. Up the M.2 to 512 and give the lady some Bling [Internal lights to set it off] Just my Advice for pretty much anything she could ask for whatever you decide you will be pleased you chose Digital Storm in the end. Please post review pictures and video of her reaction if she doesn't mind. Edited by FR3SHM3AT - 04 Oct 2017 at 11:57am |
Quote Reply Posted: 04 Oct 2017 at 12:27pm |
Build looks good.
You could get the Vanquish level 3 for less money and still get the much stronger gtx 1070 for maxing anything out there with the Asus 1080p Monitor. With Vanquish you won’t get the faster m.2 drive, but not really needed for most gamers that game and surf the web. You would also have to plug in your own WiFi card or order the external WiFi USB dongle that DS has. For the money, Vanquish is best bang for the buck, but your custom setup allows for more options, so up to you. |
Quote Reply Posted: 04 Oct 2017 at 1:06pm |
Build looks good I would go with 1070 as mentioned, Also look for your monitor and etc on amazon or newegg and make sure you are getting the best price.
If budget is an issue vanquish is less as bp mentioned, but budget is ok and you want the m.2 drive then change to 1070 and go with yours. Also change your psu to the fully modular one. IMHO you are making a mistake not ocing, ocing helps lots, it is very easy to do with these cpus. Just think about it at least. fyi for oc I would go like this: Click Image To Go To Configuration Page Think about ocing and the other stuff bp mentioned Edited by DST4ME - 04 Oct 2017 at 1:10pm |
gravity
Quote Reply Posted: 04 Oct 2017 at 2:21pm |
thank you all so mutch i think were set in stone after some changes here in there and just under budget as well now i didnt go for over clock because she wouldnt even bother with something like that but thanks for the concern now to just hit order
Edited by gravity - 04 Oct 2017 at 2:23pm |
Quote Reply Posted: 04 Oct 2017 at 2:23pm |
Our pleasure, just make sure you change the psu to the one in my config
Edited by DST4ME - 04 Oct 2017 at 2:23pm |
Quote Reply Posted: 04 Oct 2017 at 2:39pm |
Can’t go wrong with most selections, so congrats. I would get the better psu as DST mentions. A better supply, more efficient and longer warranty. Don’t want to save money with the psu.
