Bolt 3 Case Power CordPost Date: 2017-04-25 |
Masimo
Newbie Joined: 31 Dec 2015 Online Status: Offline Posts: 36 |
Topic: Bolt 3 Case Power Cord Posted: 25 Apr 2017 at 3:33am |
Hello,
I am doing a custom build for someone using the Lian Li PS-O5s case. I have a Bolt 3 myself and I was wondering the power cord that is installed to run the PSU to the back of the case. Is this a custom made cable by DS or can I find one online? Also is can order online what lengh is suggested? |
Quote Reply Posted: 25 Apr 2017 at 8:09am |
DS uses off the shelf power supplies with the cords supplied by the manufacturer.
I don't think you have a choice in the length. A heavy duty 10 amp extension cord can be used to extend it. Edited by bprat22 - 25 Apr 2017 at 8:09am |
Masimo
Quote Reply Posted: 25 Apr 2017 at 8:34am |
Thanks again bpratt. Yes I knew they used off the shelf stuff just wasn't sure what they did to extend the power form the PSU to the back of the case. Found something on amazon with your assistance, now just need to measure it out and check on how they attached it to the case.
https://www.amazon.com/Tripp-Lite-IEC-320-C14-IEC-320-C13-P004-010/dp/B008OUL372/ref=sr_1_12?ie=UTF8&qid=1493133274&sr=8-12&keywords=pc+power+10+amp+extension+cord |
Quote Reply Posted: 25 Apr 2017 at 9:42am |
Oh, I see what you meant. Yeah, the Bolt's psu sits up front and needs an extender to the back.
