CPU Fan Error!Post Date: 2015-11-25 |
Small
Newbie Joined: 25 Nov 2015 Online Status: Offline Posts: 7 |
Topic: CPU Fan Error! Posted: 25 Nov 2015 at 6:04pm |
Hello,
I have been having a problem for awhile where I get CPU Fan Error on boot. I have to enter bios and exit without saving to boot up the computer. Here are some screenshots. I am also bluescreening every so often which never used to happen. The computer is a pretty maxed out Hailstorm II. Any ideas? Thanks! -Small Edited by Small - 25 Nov 2015 at 6:04pm |
Quote Reply Posted: 25 Nov 2015 at 6:16pm |
My guess is that your bios settings changed. Go into bios and either load the proper profile then save and exit or in bios look for where you can disable cpu fan alert if you have hydrlux water cooling.
Do you still have your cpu overclock? If not then the bios did go back to default. If the overclock is still there when you check it under load then the cpu fan header is looking for a fan pluggedinto it that water cooling setups dont use. Then disable it. Hope this helps. |
Small
Quote Reply Posted: 26 Nov 2015 at 4:43pm |
I reset bios to default. Still getting the cpu fan error. Can't seem to find in there where I can disable that.
Quote Reply Posted: 26 Nov 2015 at 4:49pm |
Resetting bios to default is why it's CPU fan faulting out. Do you the CPU water cooled? If so, reload the water cooling profile you posted in the bios screen. DS will have set the CPU fan to disable because nothing is plugged into it on the mobo.
The CPU fan disable or similar wording might be under the Monitor tab. I'm not familiar with that Bios interface so just guessing. CPU fan Ignore under the Monitor tab might be what you're looking for. Edited by bprat22 - 26 Nov 2015 at 4:55pm |
Small
Quote Reply Posted: 27 Nov 2015 at 1:53pm |
Got it! Seems to be fine now. Thanks.
Quote Reply Posted: 27 Nov 2015 at 2:23pm |
Excellent.
